VideoHelp.com Forum
Results 1 to 16 of 16
  1. Member Hermit's Avatar
    Hi
    I have some three year old DVDs which only my Pioneer DVR-106D reads
    all other Burners and readers give at around 50 % with I/O error
    I want to back up around 500 DVDs which are all old
    So I want to upgrade to a faster reader
    Here at this thread I came across a interesting story
    http://www.videohelp.com/forum/viewtopic.php?t=256543
    exactly similar to mine and there Lordsmurf recommends BTC burners and LG
    My question is which Model from BTC has the best laser or which Model from LG has the best laser
    Are LG writers also good readers?
    Variable Bit Rate in DVD Recorders : A quantum Leap
    Setup
    JVC S-VHS VCR model HR-S7960E TBC/ Digipure
    JVC DR-M10S DVD Recorder
  2. I agree. I just sold my 106d. I noticed that it was a better reader than my dvd-rom. If it didn't play in my dvd-rom, I would place it in the 106d. This is going to be hit and miss for you. I would suggest a plextor burner, but that may not do the trick either. Good luck
  3. Member Ma_Jie's Avatar
    I'd recommend the BenQ1620.
    I've never had a problem ripping even very scratched up pressed DVDs.
    It's not necessary to take LS' view as gospel; there are other good readers which have been OWNED and USED by people.
    - MJ
    (1)BenQ 1620 w/ B7u9 w/ MCSE speed patch
    (2)Philips 8631 @ BenQ1620 w/ B7U9 w/ MCSE speed patch
    GET MCSE HERE
    BenQ Ownz j00
  4. DVD Ninja budz's Avatar
    A few months ago I had a badly scratched disc that only the Plextor 708A was able to read. I tried my Toshiba dvdroms, Pioneer 107, Benq 1620 & Liteon 411 drives which all failed to read the disc. If you're willing to spend the money then get a Plextor burner from which I've read is a great reader. The BTC drive is not the best burner but if you're looking for just a reader then get a LITEON CDRW/DVDROM or a AOPEN 1648A DVDROM.
  5. Member Noahtuck's Avatar
    - MJ
    Why don't you just change your username to BENQ ??
    for real, it's not like benq is the GOD of readers/writers
    Any reader/writer will do a good job depending on how it works for you 8) there are so many variables most people don't have a clue.....
    Like i stated before,
    Originally Posted by Noahtuck
    My Toshiba SD-M1712 rips at speeds you stated earlier about your "benq" and it also reads DVD-RAM & save's my burner for just that... burning... i don't even waste time using any of my burners (present or past for ripping) and for $15.00, i could buy them all day long, although i don't need to as my toshiba has lasted for 2 years now being a heavy ripping drive
    Ya know what, if it works for you.... more power to you 8)
    So much for your HACKED firmware statement the only reason NEC's were anygood or other drives
    why waste and burn up your burner prematurely unless you can't afford a seperate dvd-rom
    And budz has very good advice!!!!!!!!!
    I have used SOOOOOooo many burners and they all worked great until i burnt them up, but i do alot more burning than most people on this board so it is to be expected 8)
    I have never had any drive that would not read ANY dvd-rom, dvd-r or dvd+r!!!!! 100% of the time it's something else!!!!!! if you can't, you either have a bad disc or drive....
    And you have not been around for what ?? how long ?? and you consistantly want to challeng LS.... like you are some god like you think benq is
    But this is all my opinion from my own personal experiance....
    Originally a member since 2001, LONG LIVE TARAN's!!!
  6. C't magazine gave the Pioneer and Lite-on 100% for reading badly scratched DVDs and the BenQ was next in line. I have a BenQ 1620 and it's read every DVD I've thrown at it.
  7. Member richdvd's Avatar
    - MJ
    I agree.
    It's getting old.....REAL FAST.
    Him flapping his mouth about BenQ and taking really low shots at Lordsmurf. He's just making himself look like a fool.
  8. DVD Ninja budz's Avatar
    - MJ
    I agree.
    To Richdvd:
    And what is it that you needed to add to this post that was constructive?????????? Obviously NOTHING. In my opinion if you have nothing constructive to post regarding this thread perhaps you should refrain from saying anything. Nothing wrong with boasting what a great drive the BENQ 1620 is. But as always everyone has a opinion like we all have assholes.
    :P :P
  9. I'm going to walk around the turd pile (for the moment anyway) and comment on my Toshiba 5112 burner. While it's only an average burner, it's been able to recover about a dozen discs that none of my ~10 other DVD drives were able to extract completely, so it's an awesome drive for those crappy discs that need to be backed up, from scratched discs to discs that were poorly burned. Among other drives, I've also got two NEC burners, a Benq burner, a Liteon DVD-ROM, a Philips DVD-ROM, a Samsung DVD-ROM....none of them has stood out as being much better or worse than one another in ability to rip bad discs, although the Liteon and NEC drives can rip fairly fast.
  10. Member richdvd's Avatar
    I have a Liteon ROM that does a fairly good job.
    I find that it rips fairly fast but has trouble with some marked up discs. For the marked up discs that the Liteon chokes on, my Pioneer usually handles them, but is a little slower to rip.
    @budz-chill out...i wasn't directing any comments towards you. It's just really funny to see a member who's been here for 2 months, continually bash Lordsmurf. You and Steve know your stuff...and that's cool.
    Cheers!
  11. Member Hermit's Avatar
    Hi everybody
    Thanks for feedback
    My system already has Toshiba Sd-M1712 but it gives up these old DVDs ( they are not scratched but they were burned on low quality Ritek media and may be a weak laser) after reading 50%
    Then I have Pioneer DVR-106D which reads almost all except one in 30 DVDs
    Then I recently bought NEC-3520A but it will not read at all these old DVDs gives up after 50 % I/ O error Then I bought just a Aopen 1648 AAP pro DVD rom it is also very picky and woulld not read any of those DVDs so I returnrd both of these drives and started serious research on the net about reading Old unreadable bad media DVDs and I came across the thread where Lordsmurf suggests either BTC burners or LG . Then I talked with some of my friends in Germany and they all said the LG 8X burner was a great reader but now it is no more available
    So today I ordered LG 4163B from Amazon.de lets see if it reads ?
    Otherwise I will have to try using BTC
    Setup
  12. Originally Posted by steve2713
    I'll second the Toshiba, it reads damn near everything. I've seen only a couple of discs it wouldn't read, they had pretty deep circular scratches that ran right with the info on the disc, very hard for anything to read with scratches like that.
    Have you tried any of the cleaners/scratch fillers before you attempt to read the discs? I use a very inexpensive kit that I got from Wal-Mart for $5 and I can read about 90% of the badly scratched DVDs I get from the rental store. A very cheap solution...
  14. I use Plexus to clean all Netflix and BB discs before playing them, works excellent on fingerprints and smudges, doesn't fix scratches though.
  15. Member lenti_75's Avatar
    it's not about scrathes...it's bad media.
    I am not a plextor fan, I still use a 3 yrs nec1100, but I have a plextor cd-burner.
    recently, i had to copy a cd, of course, a bad media cd, and the plextor was the only one to work, without any errors. I tried on nec1100, 2500, toshiba dvd-rom.
    so, I would try one, if those dvd's are so important, you have nothing to loose. If the plextor dvd's are as good as cd-burners, then it should work.
  16. Member Ma_Jie's Avatar
    My post was not intended to take a "shot" at Lordsmurf. It merely was supposed to point out that the views of one individual person do not represent the be-all end-all when it comes to a particular thing, in this case DVD burners.
    I have nothing against LS or anyone here. I just think it's important that everyone get a balanced picture of things, and that cannot possibly happen if only one viewpoint is presented.
    Cheers,
    MJ
    GET MCSE HERE
    BenQ Ownz j00
  1. LG RHT497H DVD recorder - XP not reading DVDs made
    By jollysuper in forum Latest Video News
    Last Post: 28th Mar 2012, 11:01
  2. Replies: 15
    Last Post: 10th Jul 2008, 22:21
  3. Best burner for reading DVDs
    By samijubal in forum DVD & Blu-ray Writers
    Last Post: 23rd May 2008, 11:21
  4. Dvp5982 reading dvds as data files
    By themow in forum DVD & Blu-ray Players
    Last Post: 11th Mar 2008, 21:52
  5. Replies: 11
    Last Post: 2nd Dec 2007, 15:03
