I have two comps, both with Athlon XP 1800+ (same exact chip). I was about to upgrade one of the comps, but then I don't want the cpu's to go to waste, so I was wondering if there is a mobo with dual socket A. Anyone know? And would it be worth the effort?
Results 1 to 23 of 23
Boy do I love my avatar!
unless you are running a server or using high end pro programs for something like video editing dual cpu setups are useless
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
I was going to use it for my dvd burning box, reencoding with CCE and whatnot in batch mode.
In order to use dual Athlon's, you'd need the MP version of the chip. The XP's you cannot (AFAIK) run dual, at least the older version you have.
Cheers, Jim
My DVDLab Guides
well if you really would want to....
http://tyan.com/products/html/athlon.htmlPhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
Cheers, Jim
My DVDLab Guides
Originally Posted by reboot
what does it say in the blue bar above that? what socket do u think xp-m's use?
:P
I know that. If you're willing to try it, go ahead, but dual XP's of the 1800+ vintage (palomino or t-bird/thunderbird? core) won't work.
Cheers, Jim
My DVDLab Guides
my bad. you're right. has something to do with smp. tsantsa you cant run dual with the cpu's u have at all
oh well...now i gotta figure something else to do with them!
well if you have 2 working boxes why not just sell them for a few hundred each?
Hell, I dunno if they would be worth that much!
people will. trust me. look in your local paper or just ads.
I don't know about that, they game pretty well too :POriginally Posted by glockjs
You can use those XP 1800s in any dual Socket A board. You either need to do a mod to the chip itself to make it mulitplier unlocked:
http://www6.tomshardware.com/column/20011124/
Or look for a thing called the XP-TMC by Upgradeware. It's a socket that goes between the mainboard socket and your XP CPU to do that same mod without actually changing your processor. I think they're still around for sale somewhere.
My recommendation would be that Tyan 2466. You can get them on eBay for reasonable prices and it's a solid board. Beware of the 2460 like mine, it has one major issue with its power connector that will ruin your day someday.
In case you go the XP-M route they do make fantastic Athlon MPs as they draw less power than an MP.FB-DIMM are the real cause of global warming
interesting stuff. so it can be done but it just takes a little modding lol
If I do this, am I under the impression that they won't help me in doing 6 pass CCE re-encodes of dvd's?
I don't really game on my pc and I don't do huge editing deals either...
May not be worth the effort, except for the challenge, that is!Boy do I love my avatar!
If CCE supports SMP then it will work almost as good as twice one of those CPUs, more like a 1.7-1.8x increase with SMP. I don't use CCE but I'm guessing it is SMP aware.
Uh, what does SMP stand for?
EDIT: Is is Symmetric Multi-Processing?Boy do I love my avatar!
Yeah. Programs have to be written to utilize both processors otherwise they'll only see one at a time. This isn't a bad thing though since you can run two non-SMP apps at the same time without any noticeable slowdown. Very nice feature if you do a lot of multi-tasking.
TMGPEnc is SMP-aware FWIW.FB-DIMM are the real cause of global warming
Sexy Male ProstitutesOriginally Posted by tsantsa
Just kiddling, you are correct, its Symmetric Multiprocessing"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
I went to CCE's homepage and I can't find anything about it...Anyone know if CCE is SMP aware?
http://www.cinemacraft.com/eng/cpu.html
Yes, it's SMP aware.FB-DIMM are the real cause of global warming
lol, i didnt I looked at all the stats but for some reason, cpu and SMP didnt click in my mind, so I didnt click the link!
Thanks, rally.Boy do I love my avatar!
The Future of Socket 775
By wulf109 in forum ComputerReplies: 1Last Post: 29th Jan 2010, 00:55 -
Windows 7 on Socket A nice OC
By ocgw in forum ComputerReplies: 8Last Post: 8th Nov 2009, 06:24 -
INTEL 478 socket - 775 socket heatsink/fan
By blinky88 in forum ComputerReplies: 7Last Post: 7th May 2009, 10:38 -
PC AND Xbox360 into the same socket in my HDTV?
By blueyonder in forum ComputerReplies: 17Last Post: 21st Apr 2009, 17:49 -
Headphones into a SCART Socket?
By vivificus in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2007, 12:24
