Are there any MPEG2 encoders that equal the quality of Cinemacraft Encoder but is supported on the linux platform?
Results 1 to 15 of 15
Thread: MPEG2 Encoder for Linux?
"There's a sucker born every minute"
I haven't used CCE, but mpeg2enc from the mjpegtools package seems pretty good. I would not recommend mencoder for MPEG2 -- the result looks good, but it doesn't play back properly in WinDVD/PowerDVD/etc.
Every file I've converted with mencoder has work with WinDVD/PowerDVD/etc the catch is you have to get the options just right. As a matter of fact it convert video clips that TMPGEnc just thows up on. The easiest way to use mencode is to get tovid. It looks at each clip and sets the options correctly.
Tovid is the way to go for easy VCD, SVCD, DVD mpeg encoding. The files work just fine on every standalone DVD player I've tried. Sorry, don't have a windows install anymore to test play back with WinDVD or PowerDVD, but the files do work just fine with Xine, Mplayer and Totem
No, the quality isn't anything like what you'd get from TMPG, CCE(w/Avisynth) or Procoder. But for simple video to DVD for your personal use, it's more than enough.
If you require more, you can always use Avidemux, which has a few filters ported from avisynth, and has the option of using mpeg2enc or ffmpeg.
Just to double check thing out I went back to a couple of DVD's I made and played them back with WinDVD and your right they do play like crap. But the funny thing is they play perfect in my stand-alone dvd player on top of the tv and againg with Xine & Mplayer. So is it poor video encoding or a poor video playback?
It could be the multiplexing.
Most directshow codecs have trouble with certain streams. I know, when I ran windows, Power DVD had an issue playing back multiplexed VOBs, but of course played the title perfectly when I loaded the IFO.
Yeah tovid is really the app for the job, its easy (the command line isn't very hard) and produces very good results.Originally Posted by disturbed1
Frankly, it doesn't matter. I can't just cut those programs out of consideration if I want to distribute something, so I have to have good playback in them. Anyway, I get good playback with mpeg2enc streams; and the only streams I see this effect with are from mencoder, so that seems like an encoding problem to me.Originally Posted by courtrrb
hey all,
Is there a mpeg2 encoder app for linux that rivals tmpgenc? or is someone making a port of tmpgenc for linux?
thanks,
schunn99
I've had more problems using tmpgenc so I hope its never ported to Linux. If the video codec isn't exactly on standard it thows up. If you want a mpeg2 use tovid. It uses mencoder a part of Mplayer and it's easier to install then tmpgenc and all the different codecs it needs. It will convert 100+ times more than tmpgenc ever will.
Tovid doesn't use mencoder for anything. It does use mplayer to stat the video and to pipe a yuv stream to mpeg2enc (part of mjpegtools), ffmpeg for ac3 encoding, and mplex (mjpegtools also) for muxing.Originally Posted by courtrrb
Ah disturbed1 think again. Here is a few lines of code taken from tovid. So please get your facts straight before posting a comment like that.
# ENCODE VIDEO
echo "$SEPARATOR"
# If existing video is OK, skip video-encoding step
if [[ -z $FORCE_ENCODING && -n $VIDEO_OK ]]; then
echo "The video stream already appears to be in the selected output format."
echo "Video will be copied as-is."
# Copy the video stream
mencoder -nosound -ovc copy "$INFILE" -o "$OUT_PREFIX.$VID_SUF" >> $LOG_FILE 2>&1
else
[[ -e stream.yuv ]] && rm stream.yuv
echo "Creating and encoding video stream using the following commands:"
# If we're doing two-pass encoding, the commands are somewhat different...
if [[ $TWO_PASS == "y" ]]; then
VID_PLAY_CMD="mencoder \"$INFILE\" -o stream.yuv -nosound -ovc lavc \
-lavcopts vcodec=mjpeg:mbd=2 $VID_FILTER $VID_SCALE -ofps 29.97"
VID_ENC_CMD="lav2yuv $LAV2YUV_ASPECT stream.yuv | \
$YUVDENOISE mpeg2enc $MTHREAD \
$ASPECT_FMT $MPEG2_FMT $VID_FPS $VERBOSE $VID_NORM $MPEG2_QUALITY \
-o \"$OUT_PREFIX.$VID_SUF\""
echo $VID_PLAY_CMD
Originally Posted by http://tovid.sourceforge.net/documentation.html#s4p2That's a script my girlfriend is using right now to encode some niptuck eps I've captured across my NFS to dvd.Originally Posted by current running script
We must be using different versions of Tovid.
Notice it uses mplayer to extract the audio, then mplayer to resize, fps convert, then pipe out to mjpeg tools.
I just check the latest version of tovid Version 0.18b
It still has mencoder in it.
if you open it and check lines 895, 1020, 1023 you will see the mencode executable. Besides when you install it
it checks for the mplayer/mencoder executable. Since mencoder is part of the Mplayer project that would make us both right.
encoder guıs on linux
By montevo in forum LinuxReplies: 6Last Post: 22nd May 2012, 06:08 -
What would be the best free MPEG2 encoder?
By CursedLemon in forum Video ConversionReplies: 12Last Post: 20th Sep 2010, 22:10 -
AutoX264 (Multi Encoder GUI for H.264) v. 0.18 (windows/linux)
By buzzqw in forum LinuxReplies: 142Last Post: 28th Jun 2010, 13:47 -
Linux themed skin for DVD Rebuilder (for Ubuntu and Generic Linux)
By freebird73717 in forum LinuxReplies: 5Last Post: 26th Nov 2008, 20:27 -
Nero Linux 3 Delivers Blu-ray and HD DVD Data Burning Support to Linux OS
By BJ_M in forum Latest Video NewsReplies: 0Last Post: 28th May 2007, 10:23
