First of all, sorry for my english!
I wanna know does L2 cache size on CPU can improve(speed up)video encoding and decoding time, or it just does't metter
Thank's
Don't believe in MHz
Purely a guess, but I wouldn't think cache size would make much of a difference. Raw processor power is far more important than amount or speed of accessing memory in the encoding process.
The only time the size of the L2 cash makes a difference if the process that is being performed is to large that the processor has to acess the ram. If you check some reviews like a Duron vs Athlon XP at the same clock frequencies you will see some differences. If you have the money go for the one with the larger L2.
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
Do Encoding with H264 using 2 passes actually improve the quality
By prithvi in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2011, 08:30 -
Blu-ray backup/playback problems (mkv, m2ts, ffdshow, mkv splitter)
By Pyrophoric in forum Video ConversionReplies: 0Last Post: 3rd Mar 2010, 10:26 -
Encoding a Video-Divx got Size Problem...
By PzSniper in forum Video ConversionReplies: 3Last Post: 17th Sep 2009, 17:59 -
How to calculate size of video file after encoding?
By vid83 in forum Newbie / General discussionsReplies: 3Last Post: 31st Dec 2008, 01:56
Statistics
Newest guides
Latest tool updates
New media comments
