Hey, I have Pinnacle Studio 8 on my comp and it was giving me problems so i bought Pinnacle Studio 9. But when i uninstalled v.8 it said it was succesful and everything, but when i put in the v.9 install disk it always detects v.8 and won't let me install v.9. i have win. xp, and i kept uninstalling it and deleted every file i could find from it and even deleted all the keys i could find in regedit. but its still on my computer? its in my control panel add/delete programs still. And I can't get it off my Comp. does anyone know how to get it off so i can install v.9? i tried doin systm restore but i don't remember when i installed v.8 but i did at least 7 or 8 months ago and restore won't go past jan. for some reason. so if anyone can help me get v.9 on my comp. thank you.
-Rusty
Results 1 to 10 of 10
Go to Sysinternals.com and download REGMON. Run it as you try installing 9 again, and stop REGMON capture as soon as you get the message that 8 is still installed. It will show you the registry entries that the 9 install is complaining about.
At least that's how it should work.
Hey Thanks, i tried that but theres so much keys or processes that came up from the time i started to the time the window came on that i don't know what to look for? i saw the setup processes but they were at the begining and the ending when i stopped the capture didn't look like it had to do with pinnacle. it might be but i don't know what kind of process or path to look for? thanks though
- rusty
Go to the start menu ------click on the run command and type in regedit------Go into the edit tab and choose find.
Type in Pinnacle studio and hit enter. Delete the keys that it finds. Hit F3 and repeat. Keep hitting F3 and delete. This could be a lengthy process but once all traces of Pinnacle are gone, then install version 9.
thanks, i have a question though, do i delete every key/value that i get or just the ones that say pinnacle? and some of the ones i tried to delete had an error messege that said, cannot find all specific values and cannot be deleted. do you know how to get studio 8 off my control pannel - add/delete programs?
YesOriginally Posted by Rusty2286
It is in the h-key local machine tree.
Programs-----Microsoft-----Windows-----Current version------Uninstall----
Look for it in there. Delete the Pinnacle key from there and it will disappear from the add/remove programs list in the control panel.
1 -uninstall the provious version
2- delete anything from C:\Program Files\Pinnacle...
3- delete anything from C:\Documents and Settings\All Users\Application Data\Pinn... IN WINDOWS XP
C:\WINDOWS\All Users\Application Data\Pinn... IN WINDOWS 98
4- exec regedit and search for "pinnacle" and "studio"
5- remove all occurrences
6- install the new software
http://reviews.cnet.com/5208-6138-0....ssageID=666341
In the registry, drill down to this key (using Search won't find it!):
CODE
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{87D62D9 4-71B3-4b9a-9489-5FE6850DC73E}
Delete the following key:
CODE
InProcServer32
Of course if this doesnt work try
'Moveonboot'
Boot in safe mode, move the file to another folder, install "MoveOnBoot" and delete the folder using "MoveOnBoot"!
hey, thanks a lot everyone. i got it to work finnaly. thanks for your answers and help. bye
- rusty
LG HDD DVD recorder won't delete
By kimmie23 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Feb 2010, 02:27 -
Folder Won't delete
By jollyjohn in forum ComputerReplies: 4Last Post: 8th Jan 2010, 08:10 -
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 13:09 -
delete me
By doomdoomdoom in forum Newbie / General discussionsReplies: 0Last Post: 11th Aug 2007, 02:25
