Hi guys I am new to this i want to find a programs in which i can covert mpeg files and make a dvd out of it I used nero with thre decoder it came out nice but some videos had problem with the audio please help me guys in finding a good program to makle dvd's.
Thread: I have an issue
check the tools section <<<=====
lots of choices and user ratings with comments, good place to start
I use TMPGEnc encoder and TMPGEnc DVD Author. They are easy to use and inexpensive with good quality. Trial versions are available. There are others that work as well.
Making a quality DVD is mostly finding out the settings that work best for you. You might want to take a look at the DVD 'What is' to the left <<<. The most compatible audio is AC3, but MPEG-1 Layer2 is mostly compatible and makes it a little easier.
Spend a little time with the guides to the left <<<. Just about everything you need to know is there.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
I suggest using Cinema Craft Encoder aka CCE BASIC but to get the most out of it you will also need to learn AviSynth.
However that is one great combo that works very well and very fast (much faster than TMPGEnc Plus).
As for the final stage (the authoring stage) I suggest TMPGEnc DVD Author with the AC-3 plug-in. Fairly inexpensive and works extremely well. Just so as not to confuse you TMPGEnc is the MPEG encoder and is also called TMGPEnc Plus ... there is also a newer version called TMPGEnc Xpress. So to be clear I am saying use TMPGEnc DVD Author for the final stages but use CCE BASIC with AviSynth for the actual MPEG encoding.
TMPGEnc Xpress with AC-3 is not bad, especially for a simple, wizard-driven solution. Like the zombie said, CCE BASIC with AviSynth will give you great results, but you will have more to learn (which will make you a better video creator in the process).
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 22:53 -
K-lite issue then mp4 issue
By Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 10:57 -
Ripbot Issue
By Yeomans in forum Newbie / General discussionsReplies: 2Last Post: 12th Sep 2010, 07:28 -
pc to tv issue
By notaclue72 in forum Media Center PC / MediaCentersReplies: 26Last Post: 25th Feb 2010, 12:25 -
Another issue...
By nanook in forum ffmpegX general discussionReplies: 3Last Post: 21st Nov 2009, 08:47
