VideoHelp.com Forum
  1. I have a video i,m trying to make with tmpgnce dvd authour it is saying my video is 480x480 how can i change's this with out take a long time
  2. Member bugster's Avatar
    You need to re-encode to a DVD compliant resolution. With that resolution source I would reccomend re-encoding to 352x480. Take a look at the guides section for more help.
    There are 10 kinds of people in this world. Those that understand binary...
  3. Member ZippyP.'s Avatar
    Your video is SVCD resolution, it can be put on a DVD but it is not compliant so some players will refuse to play it, while other players won't mind at all. If you still wish to put it on a DVD without re-encoding then there are several guides to help you. You could do a search under All Guides> Format Conversion> SVCD to DVD.
    Here's a guide from Baldrick.
    Some dvdplayers can play non standard resolution dvds...You can bypass Tmpgdvdauth check patching the vob headers with DVDpatcher ,setting the standard 720x480..don't forget to patch-back to 480x480 before authoring starts.
    If you want anyway change resolution (safest method) , I suggest Mainconcept MPEG encoder, it gave me good results in very short times (like 110% of movie duration with an Athlon 1,3GHZ 128MB DDR )
  1. Avisynth Clips Wrong Size
    By sambat in forum Newbie / General discussions
    Last Post: 30th Jan 2011, 19:36
  2. avidemux wrong video size
    By dimoutlook in forum Newbie / General discussions
    Last Post: 20th Nov 2009, 05:33
  3. Wrong size created
    By craigarta in forum Video Conversion
    Last Post: 3rd Aug 2008, 17:20
  4. Why is this wmv file the wrong size?
    By abisti in forum Newbie / General discussions
    Last Post: 5th Feb 2008, 18:14
  5. Wrong Size at Spliting
    By Flowbax in forum Editing
    Last Post: 16th Jul 2007, 13:33
