I bought a tv card for my pc(MPEG TV STATION/PCI)-BT878/9 with
S-VHS IN. The tv is working perfect with INTERVIDEO WINDVR3.
I recently bought a DVD player with component video out/progressive(Y Pb,Pr) scan,scartcard(to tv)audio out,video out.
please i try connecting my dvd so that i can watch movies on my pc(monitor) but first and formost do not know what cable to use for that connect and if i need additional software.
my system is XP SP2
INTEL PENTIUM 4CPU 2,53GHz,255MB RAM,RADEON 9200 SERIES.
hp to get a responds
You could try using a video card with VIVO (Video In/Video Out), just connect an S-Video to the DVD Player S-Video out and the other end to the S-Video In of the Video card. The only problem is that many video cards chips come with macrovision protection and won't let you watch the content if the movie is protected with this system.
Another option is to get from Radio Shack an RF Modulator device and connnect the S-Video or Composite out of the DVD Player to the S-Video In or Composite of the RF modulator, then, using a coaxial cable from the RF Modulator you could connect it to a PC TV Tuner, the broadcast should appear in channel 3 or 4 of the TV Tuner card.
There are many cheap TV Tuner cards based on the BT878 chip and a bunch of free applications compatible with it.No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
Why not simply use the PC's DVD ROM drive and some player software?
There are 10 kinds of people in this world. Those that understand binary...
Unfortunately there probably is no common interface between your DVD player and your monitor. Your DVD player has Component/Scart/Composite and your monitor probably only has RGB.
There are Component to RGB converters, For example:
http://www.smarthome.com/777062a.html
But they run US$150 to $200.
You're best bet is what Bugster suggested, just get some DVD player software for your PC.
http://compequip.com/ProductDetails....2VGA&click=241
IMHO, These units do not handle interlace very well. I have a friend that uses one with a dvd player, and a 17 inch flat panel monitor.
Might as well watch on a TV rather than use one of those.Originally Posted by liquid217
connect monitor far
By ecos in forum Newbie / General discussionsReplies: 9Last Post: 25th Jan 2011, 20:31 -
Connect LCD PC Monitor to DVD Player
By tsloby in forum Newbie / General discussionsReplies: 1Last Post: 19th Nov 2009, 11:01 -
connect pc to another room monitor
By blader18 in forum Media Center PC / MediaCentersReplies: 2Last Post: 30th Sep 2009, 15:19 -
Connect DVD Player to monitor
By jpc82 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 22nd Jul 2007, 07:54 -
connect dvd player to pc monitor
By kiet950 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jun 2007, 11:26
