VideoHelp.com Forum
  1. Banned
    i am planning to buy a BenQ DW1620 Pro from www.newegg.com for 52.99. they have the OEM and the Retail ones, i want to know what is the difference between thoes two. thanks.
  2. DVD Ninja budz's Avatar
    there is no difference as far as hardware. the only difference is the OEM usually comes with the BULK firmware which is the "G" series firmware and to enable 4x DUAL LAYER DVD+R burning you need to upgrade to the G7P9 or later firmware. PRO usually comes with the "B" firmware that is already 4x DL DVD+R capable. Check out the BENQ FORUM at cdfreaks.com for more info.
    you can always cross flash the "G" firmware to the "B" firmware by downloading the WinDXFlash.exe file and the B7P9 cvt file from this site:
    http://dvdpro.club.st/firmware/BENQ_FW.htm
    lastly retail usually comes with bundled software and OEM doesn't.
  3. Member Ma_Jie's Avatar
    The OEM BenQ comes with the BenQ software, bit that's it I think. I can't remember if mine came with any actual burning software.
    HDDVD: please search the forums first. This issue, OEM vs. Retail/PRO, had been discussed to death.
    - MJ
    (1)BenQ 1620 w/ B7u9 w/ MCSE speed patch
    (2)Philips 8631 @ BenQ1620 w/ B7U9 w/ MCSE speed patch
    GET MCSE HERE
    BenQ Ownz j00
  4. [url=http]text[/url] Denvers Dawgs's Avatar
    I just bought the OEM one from newegg last week. Came with Nero Express. Firmware was G7Z9, flashed it in safe mode to G7P9 and burned both DL and dvd+r media (Yuden002 & MMC 004) perfectly. Personally I didn't install the Nero because I use copytodvd to burn or dvddecrypter
    What We Do In Life, Echoes In Eternity....
  1. Replies: 40
    Last Post: 29th Sep 2010, 10:47
  2. Mouse - OEM or Retail?
    By alintatoc in forum Computer
    Last Post: 6th Dec 2009, 02:31
  3. Retail vs OEM
    By bryankendall in forum Computer
    Last Post: 3rd Dec 2009, 11:32
  4. windows 7 - oem or retail
    Last Post: 24th Oct 2009, 00:05
