VideoHelp.com Forum
  1. Here is my trancode input/output
    db2# transcode -i /hdd2/masterfiles/9_1.vob --pulldown -Z 540 -J cut="00:00:00-00:00:20",logo=file=/hdd4/hc_logo.pngosdef=4 -y ffmpeg -F ljpeg -m /hdd1/tmpencfiles/1_9_1_2_0.mp3 -o /hdd1/tmpencfiles/1_9_1_2_0.avi
    transcode v1.0.0beta2 (C) 2001-2003 Thomas Oestreich, 2003-2004 T. Bitterberg
    libdvdread: Using libdvdcss version 1.2.8 for DVD access
    libdvdread: Can't open file VIDEO_TS.IFO.
    [transcode] (probe) suggested AV correction -D 10 (333 ms) | AV 348 ms | 15 ms
    [transcode] auto-probing source /hdd2/masterfiles/9_1.vob (ok)
    [transcode] V: import format | MPEG-2 (V=vob|A=vob)
    [transcode] V: AV demux/sync | (1) sync AV at initial MPEG sequence
    [transcode] V: import frame | 720x480 1.50:1 encoded @ 4:3
    [transcode] V: auto resize | 544x408 1.33:1 error 0.00%
    [transcode] V: zoom | 544x408 1.33:1 (Lanczos3)
    [transcode] V: bits/pixel | 0.271
    [transcode] V: decoding fps,frc | 29.970,4
    [transcode] V: Y'CbCr | YV12/I420
    [transcode] A: import format | 0x10001 LPCM [48000,16,2] 1536 kbps
    [transcode] A: export format | 0x55 MPEG layer-3 [48000,16,2] 128 kbps
    [transcode] V: encoding fps,frc | 29.970,4
    [transcode] A: bytes per frame | 6408 (6406.400000)
    [transcode] A: adjustment | -1600@1000
    [transcode] V: IA32 accel mode | sse2 (sse2 sse mmxext mmx asm C)
    tc_memcpy: using mmxext for memcpy
    [transcode] V: video buffer | 10 @ 720x480
    [import_vob.so] v0.6.0 (2003-10-02) (video) MPEG-2 | (audio) MPEG/AC3/PCM | (subtitle)
    [filter_cut.so] v0.2 (2005-01-05) encode only listed frames
    0 hours, 0 minutes and 0 seconds to 0 hours, 0 minutes and 20 seconds
    [filter_logo.so] options=file=/hdd4/hc_logo.pngosdef=4
    [filter_logo.so] v0.10 (2003-10-16) render image in videostream
    [export_ffmpeg.so] v0.3.13 (2004-08-03) (video) FFmpeg0.4.9-pre1b4718 | (audio) MPEG/AC3/PCM
    [import_vob.so] tccat -i "/hdd2/masterfiles/9_1.vob" -t vob -d 0 -S 0 | tcdemux -a 0 -x pcm -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x pcm -d 0
    [import_vob.so] tccat -i "/hdd2/masterfiles/9_1.vob" -t vob -d 0 -S 0 | tcdemux -s 0xa0 -x mpeg2 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x mpeg2 -d 0 | tcdecode -x mpeg2 -d 0 -y yv12
    [export_ffmpeg.so] Using FFMPEG codec 'ljpeg' (FourCC 'LJPG', Lossless JPEG).
    [export_ffmpeg.so]: WARNING: Interlacing parameters unknown, use --encode_fields
    [export_ffmpeg.so]: INFO: No profile selected
    [export_ffmpeg.so] Neither './ffmpeg.cfg' nor '~/.transcode/ffmpeg.cfg'
    [export_ffmpeg.so] found. Default settings will be used instead.
    [export_ffmpeg.so]: INFO: Starting 1 thread(s)
    [export_ffmpeg.so]: INFO: Set display aspect ratio to input
    Audio: using new version
    Audio: using lame-3.96.1
    encoding frames [000000-000598], 15.42 fps, EMT: 0:00:19, ( 1| 0| 0)
    clean up | frame threads | unload modules | cancel signal | internal threads | done
    [transcode] encoded 599 frames (0 dropped, 0 cloned), clip length 19.99 s
    Segmentation fault (core dumped)
    db2# ffmpeg -i /hdd1/tmpencfiles/1_9_1_2_0.avi -i /hdd1/tmpencfiles/1_9_1_2_0.mp3 -s 320x240 -b 500 ~martin/1.wmv
    ffmpeg version 0.4.9-pre1, build 4743, Copyright (c) 2000-2004 Fabrice Bellard
    configuration: --enable-memalign-hack --enable-xvid --enable-gpl --extra-cflags=-I/usr/local/include --extra-libs=-L/usr/local/lib --enable-faac --enable-dts --enable-faad --enable-pp --enable-mp3lame --enable-faadbin --enable-a52
    built on Feb 25 2005 06:08:02, gcc: 3.4.2 [FreeBSD] 20040728
    Input #0, avi, from '/hdd1/tmpencfiles/1_9_1_2_0.avi':
    Duration: 00:00:19.9, start: 0.000000, bitrate: 38028 kb/s
    Stream #0.0: Video: mjpeg, 544x408, 29.97 fps
    Input #1, mp3, from '/hdd1/tmpencfiles/1_9_1_2_0.mp3':
    Duration: 00:00:19.9, start: 0.000000, bitrate: 128 kb/s
    Stream #1.0: Audio: mp3, 48000 Hz, stereo, 128 kb/s
    File '/home/martin/1.wmv' already exists. Overwrite ? [y/N] y
    Output #0, asf, to '/home/martin/1.wmv':
    Stream #0.0: Video: msmpeg4, 320x240, 29.97 fps, q=2-31, 500 kb/s
    Stream #0.1: Audio: mp3, 48000 Hz, stereo, 64 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    Stream #1.0 -> #0.1
    [msmpeg4 @ 0x82edb1c]removing common factors from framerate
    Press [q] to stop encoding
    [msmpeg4 @ 0x82edb1c]warning, cliping 1 dct coefficents to -127..127
    frame= 599 q=0.0 Lsize= 1kB time=20.0 bitrate= 0.2kbits/s
    video:1377kB audio:156kB global headers:0kB muxing overhead -99.964520%
    It produces the file searchtheboards.com/1.wmv
    any suggestions on how to fix it?
  2. The question is not related to ffmpegX, you should better post to transcode & ffmpeg lists.
  1. Replies: 14
    Last Post: 30th Mar 2011, 12:04
  2. VOB to .H264 FFmpeg Transcode Bitrate and Slow Seeking
    By Gloriosis in forum Video Conversion
    Last Post: 9th Sep 2009, 14:34
  3. ffmpegX 0.0.9 - no sound in the output of a transcode
    By mattr in forum ffmpegX general discussion
    Last Post: 21st Sep 2008, 02:56
  4. VCR/DVD combo with RF output?
    By tac7 in forum DVD & Blu-ray Players
    Last Post: 5th Jan 2008, 11:17
  5. Replies: 1
    Last Post: 30th Jul 2007, 13:19
