VideoHelp.com Forum
    I have my ps2 that I want to listen to my music from my cd player while I play it through the same speakers. I've been using two Y-adapters in the inputs of the receiver, making two outputs from each L and R channels, then hooking up my ps2 stereo cables and cd player audio cables into. The problem is that I have to turn the receiver up alot to hear it, b/c the ps2's sound drops far lower than the cd player. Is there a cheap solution to this? My cd player has volume control, and so far I have to turn the sound effects all the way up on my ps2, and turn the music all the way down on the cd player except 1 notch to balance it out.
  2. Member Shadow57's Avatar
    edit
  3. Member edDV's Avatar
    entry level
    http://www.radioshack.com/product.as...t%5Fid=32-2056
    Mix aux1 vs aux2.
    Exchanging labor for $ you can use this geek solution.
    http://www.wintektx.com/extras/making.htm
    http://www.wintektx.com/products/PAM/
  1. Replies: 2
    Last Post: 30th Apr 2011, 11:22
  2. Realtek HD has no Stereo Mix?
    By EwanG in forum Audio
    Last Post: 4th Sep 2010, 08:53
  3. Creating a Pseudo 5.1 Mix from Stereo Source Using V.I.
    By guns1inger in forum User guides
    Last Post: 27th Jul 2009, 17:21
  4. Replies: 0
    Last Post: 23rd Feb 2009, 03:32
  5. Computer to stereo receiver - no sound
    By dadrab in forum Computer
    Last Post: 23rd Apr 2008, 13:56
