is there a newbie guide for doing this i am very stuck
Thread: trying to save mpeg onto dvd
please change your avitar
please read the guides on the left
please have a good time"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
please, please, change your avatar. Have her turn around
member since 1843
Hi borofan,
First, your MPEGs must be DVD compliant. See "What Is... DVD" (top left of the page) for the specs.
Then, to get MPEGs on to DVD you need to "Author". Look in the guides for authoring, and there are numerous tools too:
DVDAuthor GUI
GUI for DVD Author
TMPGEnc DVD Author
are ones usually recommended to start with.
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Best way to go from AVCHD, date/timestamp it, and save as Mpeg 2.
By pf4711 in forum Newbie / General discussionsReplies: 7Last Post: 22nd Feb 2012, 15:07 -
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 14:55 -
How to Edit MPEG with VDubMod and save as MPEG?
By DVFun in forum EditingReplies: 11Last Post: 3rd Nov 2009, 14:32 -
Isolate Audio In This MPEG-2 File, And Save As WAV (or any other format)
By onesikgypo in forum AudioReplies: 0Last Post: 22nd Feb 2009, 04:14 -
Edit DVR .TSP and save as MPEG
By ZoNE97 in forum Video ConversionReplies: 5Last Post: 30th Aug 2007, 07:20
Statistics
Newest guides
Latest tool updates
New media comments
