I have the Panasonic DMR-E30 and it won't work. I took it in to be looked at and was told the digital board was bad. The unit shows the time and date on the display, but will not turn on. It will cost me $489.00 to fix it. The unit is almost 2 years old. I tried to contact Panasonic, but they won't do anything w/o my receipt (which I have not been able to find yet). I have offered to send them the whole unit so they could see the mfg date is 10/2002. Anyway, does anybody know of a place or person that might be able to troubleshoot the unit and find the bad component instead of replacing the whole board? Anyone know where I can get a used board? Does anyone know which board is the digital board. Any help or suggestions will be greatly appreciated. Thanks!!
"Come get some!"
Why not buy a used DVD recorder instead? I've seen Panasonic E50's in good shape go for a little over $100 on eBay lately. That's what I'd do.
I'm with gshelley61!!!!Originally Posted by gshelley61
It would be insane to pay that much to have it fixed!! that's more than twice what i paid for mine brand new
And you can get newer models for alot less!!!
& even doing what you suggest could be as, if not more, expensive than buying a new one.
Originally a member since 2001, LONG LIVE TARAN's!!!
You can get a new e55 for around $150 at walmart.....
btw, that panny of yours can fetch $50+ at ebay.
I got mine 2 years ago too, $444, but came with a free panny dvd player after rebate.
I know new oes are affordable, I was just hoping to get some info and repair my other one and have 2. My wife would never let me get a second one, so if I can fix it, I can be really obsessed. Thanks.
"Come get some!"
Buy a used one on ebay & put the board in yours....There are some on ebay that might have a board that works but not a drive for example.
OK, I bought a used on on EBay. Which of the boards is considered the digital board? If anyone knows, please let me know. Thanks!
"Come get some!"
Firmware problems panasonic dmr ez 27
By rick09 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 23rd Sep 2011, 21:22 -
Panasonic DMR-EZ485V recording problems
By ray best in forum DVD & Blu-ray RecordersReplies: 37Last Post: 7th Sep 2011, 17:38 -
PANASONIC DMR-EZ48V tuner advance problems
By PLEIADES in forum DVD & Blu-ray RecordersReplies: 5Last Post: 12th Jul 2009, 17:32 -
panasonic dmr E30 compatibility
By jimakros in forum DVD & Blu-ray RecordersReplies: 5Last Post: 22nd Dec 2008, 12:19 -
More Panasonic DMR E85 problems HELP!!!!!!!
By MOTUfan in forum DVD & Blu-ray RecordersReplies: 16Last Post: 20th May 2007, 18:36
