VideoHelp.com Forum
  1. I am having a problem with burning Video.
    After I create the VOB files I have played them on the computer ( before burning them) to check quality. They are smooth without any artifacts.
    Problem is after I burn them to the DVD I get video and sound problems ( artifacts and pauses in both sound and video) every 5-10 seconds throught the video. I have tried burning without compression and still get the problem.
    I have tried playing the DVDs on 3 different brands of DVD players (none of which has had problems in the past with the media I am using). And played the dvds on 2 seperate computers. When playing one of my attempts on each computer/dvd player the artifacts/pauses are in the same spots, but the problem spots differ between each burn.
    Software used to burn:
    DVD Decryptor
    intervideo DVDcopy 2
    TMPGNC Author
    Plextor Tools
    Media
    Imation DVD-r
    TDK DVD-rw
    TDK DVD+r
    System
    AMD 64 3500+
    1 Gig memory (dual channel) 3200
    MEDIA
  3. Okay what about the media?
    I looked up the media on this site and nobody had posted any problems with it. Is there a better place to look up media? No offense but just stating media does not help me a whole lot.
  4. Member Sifaga's Avatar
    what program are you using to burn with ?
    are you getting the pauses off the DVD when you play it on your standalone or your DVDRom or both
  1. Burning files on DVDs
    By carlmart in forum Computer
    Last Post: 23rd Sep 2011, 10:46
  2. Problems Burning Movie Files onto blank Dvds-RW disks
    By tealmarlin in forum Newbie / General discussions
    Last Post: 1st Jan 2009, 11:18
  3. help burning dvds
    By bunty90 in forum Authoring (DVD)
    Last Post: 3rd Aug 2008, 12:53
  4. burning dvds
    By terrie29 in forum Newbie / General discussions
    Last Post: 7th Oct 2007, 18:08
  5. Burning HD DVDs...Help!
    By selim97 in forum Authoring (DVD)
    Last Post: 14th Jun 2007, 20:37
