I know it's a problem with certain media and certain drives reading that media, but why would a drive completely lock the system just accessing the media?
Using a older DVD player (NEC DV-5700a) and trying to read a burned DVD with data on it (not a movie) when I try to run Nero CD-DVD Speed the system competely locks up to a point even Task Manager can't stop the 'not responding' process and only a restart will work (using the reset button).
I tried the same disc on the other optical drive (NEC ND-3520a and it runs fine. Obviously it's a issue with the older drive, but why does it lock the whole system up even after I eject the disc?
Also, in general when any disc is inserted into any drive that I have had there is the time it takes for the system to reconize the media where ther system is frozen. I have seen that from day one and just lived with it. I assume that is normal, but thius day and age one would thnink that whatever that bug is it would of been dealt with by now.
Win 2k w/sp4
nForce2 MB w/ latest bios.
Ultra DMA 33 enabled on both oprtical drives on the same IDE channel
only 15 processes running at startup
Results 1 to 1 of 1
When not in use, turn off the juice!
LG RH-7500 Optical Drive problem
By DJ_Bite in forum DVD & Blu-ray RecordersReplies: 12Last Post: 3rd Jan 2012, 12:19 -
optical drive can read but will not burn
By marx321_04 in forum DVD & Blu-ray WritersReplies: 10Last Post: 6th Nov 2009, 05:50 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 19:59 -
Optical drive problem with Nero cd
By mikehende in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jul 2008, 16:57 -
DVDRW drive cant read DVD Movies - Is it Region Locking or ... ?!?
By quantass in forum DVD & Blu-ray WritersReplies: 7Last Post: 8th Apr 2008, 22:45
