Anyone encountered this before?
I have used Melody printable DVDR for a long time and have had about 95% success rate. Recently however some of the DVDs I burn play fine but have difficulty ejecting( the tray comes out but the DVD remains inside the player). Lightly sandpapering(very fine sandpaper) the centre seems to fix this issue. So the hole in the middle of the disks seems to be where the problem occurs.
What say you all?
Results 1 to 11 of 11
Thread: DVD problems ejecting!
~Firefly - Keep Flying~
Buy different discs.
Just a guess, but you mentioned that the discs were printable, and it's possible that the ink is sticky enough to cause the disc to stick to the chuck plate (that's the arm that clamps the disc inside the player) disc clamper assembly.
If the ink isn't totally dry, or it's used in a dampish environment, it could stick. I used to see this happen on some cd's that had labels with glossy paper.
If it only happens on discs with print ink on them, it is likely the cause. But, if it happens on the same discs before you print to them, then Bazooka's suggestion is better.Ethernet (n): something used to catch the etherbunny
I dont believe that to be the case as most of the problem disks havent been printed onto yet.
Lightly sanding the centre hole with very fine paper fixes the issue.~Firefly - Keep Flying~
Hmmmm ... this sounds pretty on topic to me. What's it doing in the off topic forum?
Reporter: Mr. Hitchcock, is it true you said that actors are like cattle?
Alfred Hitchcock: I said no such thing. I said that actors should be treated like cattle.
Still beats Premature Ejection anyday....
Hello,
Ohh... good one
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
No applause....just throw money....
Hello,EDIT
moved to media
Good idea moving thread to Media forum.. I didnt even see that forum when I looked before. As my wife would say "you must've had a boys look".
Problem with ejecting disc
By blup_00 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 22nd Jun 2010, 03:48 -
Panny AG-1980 makes a squealing sound while rewinding and ejecting tapes
By OldMedia in forum RestorationReplies: 4Last Post: 4th Apr 2010, 07:49 -
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 16:25 -
LG IH-E9674 not ejecting or reading
By kurt99 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Nov 2009, 09:37 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 14:34
