VideoHelp.com Forum
Results 1 to 9 of 9
  1. Hi guys,
    Which software is best for photos to DVD MPEG with good 3D transition effects?
    I've tried ProShow, it is pretty good but only has a few 3D transition effects.
    One of them I've seen on the web is the 3D-Album, but am I right that it doesn't seem so popular? anyone knows other good software out there to do this?
    That is probably the most comprehensive, 3d focused product I have seen for doing this sort of work. It doesn't get mentioned here much because few people seem go for that type of effect.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Member Wile_E's Avatar
    Probably ProShow is your only hope right now. Most people don't convert regular pictures to an MPEG movie. This loses quality and you lose the original pictures if you don't back up your JPG pictures.
    I have a DVD player(Panasonic DVD-S47) that reads JPG files from a CD-R. I put all my pictures in folders on the disc, and then I can flip through them using this dvd player. It also has a slideshow timer to automatically flip through pictures every few seconds. Plus, the people I give this disc, then have the original JPG pictures so they can print them out or do whatever with them.
    Look for a DVD player that can play JPG's. It is a better way to go then converting to MPEG movie.
  4. I agreed with WILE,proshow is the best choice..
    The 3dalbum software is great for 3d effect,but the conversion process
    is very slow also adding music is a pain...
    You can make your album[go to bed]then add music later with
    another prog [SYNC]
  5. i'm tring to make slide show using proshow gold but the quality of the pics are not very good. I wonder if any thing to do with rendering resolution?
    which resolution should I use? or maybe I missed something? Help ..
    thanks
  6. Originally Posted by funniest
    Hi guys,
    3D-Album is what you're looking for. Believe me, when you get use to it, you'll love it. And it does a professional job that no other software out there does(3D flipping Album's suck if compare to this soft)...
    You're correct just a half (base on your statement), its capture process is in real time and as fast as you can imagine if you know how to setup/use it (The most important is you have to select the "hardware" capture instead of "software" in setup option)
    You're wrong! "....few people seem go for that type of effect." are usually professsional users which use this soft for business...
    And in addition, this software offers alot of different usefull and beautiful themes... check it out @ www.3dtime.com
    You can buy a standard Pro version for $70.00 and built your project and then capture you work in mpeg-2 (DVD format). After that, you can use your authoring soft to edit and author DVD...
    Note: You don't have to add music when you build and capture you work in 3DAlbumk. Instead I usually add music, logos when I edit and author DVD....
    These are just my opinion!
  7. 3D-Album is what you're looking for. Believe me, when you get use to it, you'll love it. And it does a professional job that no other software out there does
    Demen, I couldn't agree with you more. We were constantly looking for stock video animations to enhance our DVD productions. Until we find the porgram 3D-Album and the templates from 3DTime, it has been very hard for us to find suitable title animations for various special events that we have to deal with. They continously publish more and more fantasitic templates(you can see their new release at www.3dtime.com). Their templates saved us a lot of time to make many custom animations for DVD menus and video openings.
  8. You're correct just a half (base on your statement), its capture process is in real time and as fast as you can imagine if you know how to setup/use it (The most important is you have to select the "hardware" capture instead of "software" in setup option)
    Please note: 3D-Album Capture is not a real-time video capturing system.
    It will capture every frame (the complete animation) as well as the sound. The average
    performance compared to real-time animation is about 1:3, depending
    on the complexity of the scene. That is, a one minute movie would require 3
    minutes to finish. To capture a long movie, we suggest you try and the
    test several short ones before the final production.
  9. 1:3 is fine. Other video editing software cannot give real-time either for dvd mpeg encoding, especially when lots of overlays and effects are involved.
  1. Replies: 37
    Last Post: 9th Aug 2010, 23:16
  2. Replies: 4
    Last Post: 5th Apr 2010, 23:54
  3. Best software to edit photos
    By bryankendall in forum Newbie / General discussions
    Last Post: 17th Jan 2010, 14:41
  4. photos to video software for windows 7
    By troyvcd1 in forum Video Conversion
    Last Post: 6th Nov 2009, 12:08
  5. Photos off DVD video made of photos?
    By 5chandlers in forum Newbie / General discussions
    Last Post: 16th Aug 2009, 12:31
