I currently have a pci ide controller installed in my 2nd pci slot. I would like to add another one......is this possible under Win XP?
Results 1 to 16 of 16
Nothing is impossible for DiLeMmA says so!
See my guide on how to batch author dvds!
http://www.videohelp.com/forum/viewtopic.php?t=255213
Yes.
Why would you need 12 drives?Cheers, Jim
My DVDLab Guides
I have 4 hard drives and two dvd burners.
Why not?Originally Posted by reboot
4 hard drives and 2 burners still leaves 2 empty slots...
Better to get larger drives, and partition them.
You're going to need 2 PSU's
Cheers, Jim
My DVDLab Guides
Isn't 450 watts enough? Also, who do you recomend for a harddrive supplier (Western Digital, Seagate, MAxtor, Etc.)
I think you can get PCI IDE controllers with 3 channels on them. (2 devices/channel).
450w will run the system, probably 4 drives, and peripherals. Beware than USB uses power too.
Try this page to see how much power you need: http://www.jscustompcs.com/power_supply/Cheers, Jim
My DVDLab Guides
my personal preference is Maxtor DiamondMax Plus drives
Maxtor is currently the only MAJOR manufacturer of IDE hard drives compatible with ATA/133, everybody else still only makes ATA/100 drives
i've been looking into SATA drives, but the 10,000 RPM drives are still a bit too pricey for my tastes"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!"
I like Seagate. Very quiet.
Others prefer WD.
Whatever you get, make sure it's got the 8meg buffer, not 2meg.Cheers, Jim
My DVDLab Guides
Seagate. Cool, quite, 5 year warranty.
For your amusement- I had two controller cards in a 486 with 6 hds and a cd rom. It ran 3 months before the smoke rolled out of the PSU.
Edit- No pics, It looked like Frankensteins processor!A good divorce beats a bad marriage.
Now I have two anniversaries I celebrate!
SweeeetOriginally Posted by otpw1
no pics?????
JSB
450W should be fine. I'm running way more than that on a 550W so as long as you've got a solid brand it'll be fine.
FB-DIMM are the real cause of global warming
Do not use two PROMISE controllers at once. General advice: buy VERY DIFFERENT PCI cards, but yes, it works.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
i have 5hds 4 optical drives ,and all 5 of my pci slots filled, and my computer runs all night evey night on a 600 watt psu.....my recomendation would be to only upgrade your psu to as bib as possible
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"?
Booting from PCI IDE
By AuroEdge in forum ComputerReplies: 9Last Post: 12th Nov 2009, 01:22 -
Multiple SATA controllers
By mysts in forum ComputerReplies: 3Last Post: 3rd Mar 2009, 04:41 -
IDE Controllers - Do I have it Correctly
By mn072065 in forum ComputerReplies: 10Last Post: 9th May 2008, 22:13 -
pci ide controller problem
By makemepure in forum ComputerReplies: 4Last Post: 29th Apr 2008, 21:20
