ive seen a few homemade tv series dvd where it can fit more than 10 episodes per DVD-R disc. THe best thing about it is that it even has a dvd menu with all the VIDEO_TS folder and stuff.
So is there any way to have avi files on a dvd disc with dvd menu linking to each episode. Or maybe convert it to another format thats slightly larger.
This dvd disc doesnt necessarily have to be played on a dvd player... if it doesnt work on a dvd player, then thats alrite as i am most likely to be playing it on my pc dvd drive.
Note... it would be best if i can select audio channels and subtitles as the file that im trying out with is OGM (2 audio 1 subtitle).
you cant have any avi in dvd-video.
the new divx media format may be something for you
http://labs.divx.com/archives/000050.html
what kind of files does DVD LAB allow for video stream...
beside the usual DVD-format...
Only the usual dvd-format, mpeg1 and mpeg2 video.
...mm....are there any other software (free trial) that supports other formats beside those...coz when they are encoded...they are HUGE...
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Hoe to create a DVD menu with link to AVI files
By OggO1984 in forum Newbie / General discussionsReplies: 3Last Post: 14th Dec 2009, 15:01 -
Looking to convert scr files (screensaver slideshows) to avi or mpg format
By wiltonp in forum Video ConversionReplies: 1Last Post: 23rd Jun 2008, 17:28 -
Best format to save AVI files on PC
By bpatters69 in forum Video ConversionReplies: 6Last Post: 31st Mar 2008, 08:31 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23
