ok, here's the situation.
there is a movie that's only on VHS in the US and UK, on german region 2 (ie, PAL) DVD. the only problem is, the audio is german language only. there's no original english language track.
however, i have downloaded the movie as a 23.97fps AVI.
what i want to do, is have my english audio from the AVI synced to the existing mpeg video (that i can rip from the DVD). then i'd re-author the DVD.
should i re-encode my video as a 23.97fps mpeg-2?
should i change the sample rate of the audio to sync up with PAL?
how can i make sure the audio is synced with the video?
i don't know what way is best.. has anybody done anything similar to this before?
thanks
-Mark
Swim with me
And we'll escape
All the trouble
Of the present age
Finally free
It probably doesn't matter much which way you go. Purists would say reduce the video to 23.976 as it is closest to the original film framerate of 24 fps. If you can play NTSC (you should be able to) then that's probably the easiest way to go. The only way to see if it's in sync is to do a sample - say 5 minutes, then check to see if it works. Unless it is very slowly going out of sync, 5 minutes should let you see any issues.
This is very difficult to succeed, not from a technical point but from a practical one!
Scretch the audio so to match the PAL video is the easiest thing to do. IMO always
If you are lucky, and it is the same movie edit, that shall work.La Linea by Osvaldo Cavandoli
thanks guys. any idea what program(s) to use to make sure it's in sync?
Swim with me
And we'll escape
All the trouble
Of the present age
Finally free
PAL converted from NTSC source - Ghosting and interlacing
By OngekibouRekka in forum Video ConversionReplies: 7Last Post: 3rd Dec 2011, 12:20 -
Hauppauge PVR-150 (PAL Version) Recording NTSC Source: Impossible?
By darkarn in forum CapturingReplies: 53Last Post: 16th Aug 2010, 10:06 -
Video in PAL and Audio from NTSC source
By jairovital in forum Authoring (DVD)Replies: 30Last Post: 17th Jun 2010, 13:16 -
IVT with AVISynth of source that has both PAL and NTSC conversions
By csdesigns in forum Video ConversionReplies: 9Last Post: 10th Feb 2009, 13:15 -
Sample error on separate source means video & audio out of sync!
By christowe in forum MacReplies: 3Last Post: 13th Jan 2009, 13:22
Statistics
Newest guides
Latest tool updates
New media comments
