VideoHelp.com Forum
Thread: Stupid Active X
  1. Member gooberguy's Avatar
    I keep getting this error, and it prohibits me from using nortons properly
    This is weird because i have enabled all active X in security settings.
    I have win xp pro service pack 2.
    Thanks in advance
  2. Member gooberguy's Avatar
    bump
    I really need help with this
    Now i realized i cany even update my bios because it says the same thing in the update bios program!
  3. Member glockjs's Avatar
    PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
  4. Member glockjs's Avatar
    "Your current security settings prohibit running Active X controls on this page. As a result, this page may not display correctly."
    "An ActiveX control on this page is not safe. Your current security settings prohibit running unsafe controls on this page. As a result, this page may not display as intended."
    Cause:
    One or more ActiveX preferences is incorrectly set to "Disable" in your browser's security settings.
    Solution:
    Enable ActiveX. In Internet Explorer 5.5 and above:
    From the Tools pull-down menu, choose Internet Options.
    Click on the Security Tab, then click on Custom Level.
    Insure that "Run ActiveX controls and plug-ins" and "Script Active X controls marked Safe for Scripting" are both set to "Enable."
    Click OK to exit Security Settings. If you get a warning message that asks "Are you sure you want to change the security settings for this zone?", click Yes.
    Click OK to exit Internet Options.
    http://support.ninthhouse.com/troubl...asp?kb_id=1291
  5. Member zzyzzx's Avatar
    I was wondering if there is a way to disable ActiveX without getting all the nusiance pop ups.
  1. Stupid Flanders with his stupid iLoHD04 problems!
    By Batchman in forum DVD & Blu-ray Recorders
    Last Post: 4th Mar 2011, 17:41
  2. How to tell active codec?
    By The111 in forum Newbie / General discussions
    Last Post: 2nd Nov 2009, 06:19
  3. Active Buttons on DVD Menu
    By dartmanx in forum Authoring (DVD)
    Last Post: 22nd Jun 2009, 04:53
  4. always black borders even though full zoom is active
    By magmo in forum Blu-ray Ripping
    Last Post: 31st Dec 2008, 02:50
  5. Automatically open WinDV when DV device becomes active
    By jabloomf1230 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 9th Jun 2007, 22:30
