Hi All
Is it poss to record a prog on my Pioneer 220 recorder and just end up with one video file insted of several files? i want to edit out adverts but i have 3 video files and when joined up on my pc it is impossible to get a complete prog without jumps when joining files, any ideas?
Thread: Pioneer 220 recorder
Just rip with DVDDecrypter and in the setting tab....check (or set) file splitting NONE.
Works a treat! thanks for that
No Problem..
Everything going great, edited out the adverts in Womble mpeg editor , i now have a file which i can play in windows, however i cant seem to burn it to dvd using clone dvd, am i missing something??? thanks again
CloneDVD?.....YUK...
Now you need to re-author that thing.
TDA (follow the link) is not free but I believe it is still a 30 day trial.
Other than that you are stuck with either IFOEdit or VOBEdit ....one of those two (forget which one) can do a simple re-author...but are a bit scary looking at first.
Thanks for all the info, i have just downloaded TDA 30 day trial, and imported the file i created with DVD Decrypter, edited out the adverts with TDA and created a video file which i can import into any burning software, great, seems too easy? it would seem i only need this prog to do everything inc editing, seems to be a prog worth buying.............
One last thing, i have a number of RM video files which i would like to edit and burn to dvd as mpeg so i can play them in my stand alone player, any ideas?
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Pioneer 220-S Replacement
By Shadow1861 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Dec 2008, 10:52 -
Pioneer DVR-220 and playing dual layer problem
By whitemtntn in forum Newbie / General discussionsReplies: 4Last Post: 7th Jul 2008, 18:12 -
DVD Player Compatible with 2004 Pioneer DVR 220-S VR Mode of Recording
By iloveamerica11 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Dec 2007, 11:14
