VideoHelp.com Forum
  1. I wasn't exactly sure where to put this.
    I just bought a brand new 8x dual format firewire dvd burner from Lacie. I got that on friday and it's worked perfectly for two days. Today (sunday), OUT OF NOWHERE, it stopped being recognized in Toast. It simply does not show up.
    I'm running 10.3.8 and Toast 6.0.7. The drive is recognized in the system profiler. However, there is a carrot (>) in front of it.
    what's going on? I'll be really bummed if the drive is bummed.
    http://www.lacie.com/support/drivers/index.htm
    try going here under optical and downloading this
    LaCie DiscRecording Support 1.17 for Mac OS X 10.3.2 or later (January 24, 2005)
    not sure if it'll work, but dsp wouldn't recognize our drive the other day so we dl this and now it worked. or try toast 6.09
    pants on, pants off, pants the floor.
    You don't say what all you've done to troubleshoot this. The first thing is to shut down your Mac and turn off the drive. Then restart and turn it back on.
  4. Originally Posted by Frobozz
    I'm sorry, you're absolutely right. After fiddling with the cables for an hour, repairing permissions, using tech tool pro, and scouring the internet for similiar issues. I just turned the computer and drive off and let it sit for 10 minutes. I'm on a Tibook G4 500 so I hit the pmu reset button as well. (haven't done that in a while). When I turned the comp back on everything was working again. So either resetting the pmu or just turning the comp off fixed the problem. what a relief!!
    thanks.
  1. Problems with Lacie Lacinema Classic
    By otinimeg in forum Newbie / General discussions
    Last Post: 12th Mar 2011, 18:44
  2. Pioneer DVR-543HS , is my DVD burner toast?
    By stew182 in forum DVD & Blu-ray Recorders
    Last Post: 27th Sep 2008, 12:57
  3. lacie 16x dvd burner keeps finding miscompares while verifing dish
    By loveberg50 in forum DVD & Blu-ray Recorders
    Last Post: 29th Apr 2008, 18:30
  4. Problem writing on BD-R with a Lacie d2 Blu-ray burner
    By L7dra7 in forum Authoring (DVD)
    Last Post: 22nd Jan 2008, 21:03
  5. LaCie / Toast / DVD+R DL Error
    By webstar in forum Mac
    Last Post: 4th Aug 2007, 11:53
