I just got this new burner yesterday as I have read great reviews and that it can write 8x at 12x. I installed it in a freshly rebuilt Win2k system, updated the firmware to B7P9 and set off to burn. I attempted a DVD iso with DVDdecyrpter and it would only burn at 1x (varied from 0.7 to 1.1). So I rebooted and tried another burn with a VIDEO_TS folder in Nero 6 with a different media (Ritek G05 compared to a TY I tried first). And the same thing. It said it was burning at 16x but took well over an hour to burn. This is my 4th burner and I have never had an issue like this. My media tests out with Benqs Qscan upto 8x. I have now just flashed to B7T9 and no change. Could someone offer suggestions. Thx in advance.
Sounds like your computer is set up for pio mode and not dma. Do a search on this site and you will find what you need.
http://club.cdfreaks.com/forumdisplay.php?f=92
BENQ DVD burner is picky about media. I upgraded the firmware of my DW822A to DL(BLC-2) and some of my existing -RW won't work. It was OK in the past. Try stick to + media.
mine hasnt been picky at all. i use both + and -. mine seems to perfer ritekG04 even though others say that thiers hate that brand of media.
use this link on HOW TO ENABLE DMA in WINDOWS 2000
http://www.cdrlabs.com/phpBB/viewtopic.php?t=9668
btw i burn dvd-r with my benq 1620 and have no problems at all. use either firmware B7P9 or B7T9. just don't use PRODISC because the BENQ 1620 doesn't seem to like that media code. it's well documented in the cdrlabs forum.
hey budz did u check out the sale at supermedia store for ty media? even though they are 4x my benq loves them 2 but not as much as it likes the riteks
Try toggling write speed in DVDDecrypter, then leave it at 8x or whatever speed QScan recommends. I had a few do the same thing when write speed was set at "Max" in DVDDecrypter. Good luck.
Check out the BenQ hardware sub-forum at cdfreaks. IMO the firmware for this drive is not yet completely satisfactory. That said, I'm delighted with mine.Pull! Bang! Darn!
Looks like my benq 1620 may be dying, any writers burn 8x @ 12x?
By Denvers Dawgs in forum DVD & Blu-ray WritersReplies: 10Last Post: 27th Jul 2009, 12:05 -
Benq 1620 tray will not open? Just makes a click sound.
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 23rd Jul 2009, 00:12 -
Benq 1620 $25 after instant savings
By bevills1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 16th Oct 2007, 10:01 -
How to burn faster
By Finfarin in forum Authoring (DVD)Replies: 2Last Post: 2nd Jul 2007, 18:19 -
Benq DW 1650 suddenly won't burn TY02
By smitbret in forum DVD & Blu-ray WritersReplies: 13Last Post: 14th May 2007, 14:15
