VideoHelp.com Forum
  1. Hey sorry to be posting all the time lol
    But this is strange, i hit auto fit and get this unhandled error msg
    Something about JIT as well, dunno if thats the problem tho?
    i could jus use shrink but this would work betta.
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ArgumentException: The path is not of a legal form.
    at System.IO.Path.nGetFullPathHelper(String path, Char[] invalidPathChars, Char[] whitespaceChars, Char directorySeparator, Char altDirectorySeparator, Char volumeSeparator, Boolean fullCheck, String& newPath)
    at System.IO.Path.GetFullPathInternal(String path)
    at System.IO.FileInfo..ctor(String fileName)
    at x3284ccece41ee22b.xece14591aa1abb99..ctor(Guid xe423f530b92aa05c, String xd168ac2ed64c4662)
    at x3284ccece41ee22b.xece14591aa1abb99..ctor(String xd168ac2ed64c4662)
    at x3284ccece41ee22b.xb6dca8349e33d934.x2c1adc026e1a2 166(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    SVCD2DVD
    Assembly Version: 2.0.1867.33802
    Win32 Version: 2.0.1867.33802
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/SVCD2DVD.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    DevComponents.DotNetBar
    Assembly Version: 4.7.0.0
    Win32 Version: 4.7.0.0
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/DevComponents.DotNetBar.DLL
    AxInterop.CodeLock
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/AxInterop.CodeLock.DLL
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    Accessibility
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    Interop.CodeLock
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/Interop.CodeLock.DLL
    Interop.QuartzTypeLib
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/Interop.QuartzTypeLib.DLL
    System.Design
    CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
    SVCD2DVDLib
    Assembly Version: 1.0.1867.22426
    Win32 Version:
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/SVCD2DVDLib.DLL
    Microsoft.VisualC
    Assembly Version: 7.0.5000.0
    Win32 Version: 7.10.3052.4
    CodeBase: file:///c:/windows/assembly/gac/microsoft.visualc/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualc.dll
    Interop.NEROLib
    Assembly Version: 1.3.0.0
    Win32 Version: 1.3.0.0
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/Interop.NEROLib.DLL
    CustomMarshalers
    CodeBase: file:///c:/windows/assembly/gac/custommarshalers/1.0.5000.0__b03f5f7f11d50a3a/custommarshalers.dll
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
  2. Member ChrissyBoy's Avatar
    Can you save the project just b4 you hit autofit and either attach the s2d file to your reply or email it to me please?
  3. Okay here it is
  4. Member ChrissyBoy's Avatar
    It is because you have menu settings set to custom audio but no file for the custom menu audio. Can you either choose silence or provide a audio file?
    Remember to save your settings.
  5. Oh yes i left that on since the last menu which i did have an audio file in use... thanx chrissy working now.
  6. Member ChrissyBoy's Avatar
  1. Media Player Classic: Auto Zoom: Auto Fit logic
    By DRP in forum Software Playing
    Last Post: 29th Apr 2010, 08:59
  2. auto fit
    By roystheboy in forum SVCD2DVD & VOB2MPG
    Last Post: 1st Jun 2008, 05:23
  3. Help: Computer wont turn on!
    By NateDizzle in forum Computer
    Last Post: 20th Nov 2007, 13:10
  4. Auto-fit seemingly creating larger DVD's
    By Azza_b in forum SVCD2DVD & VOB2MPG
    Last Post: 16th Oct 2007, 16:08
  5. whats the dl box under auto fit for?
    By djspud in forum SVCD2DVD & VOB2MPG
    Last Post: 5th Aug 2007, 18:25
