Hi all. I have used Pinnacle Studio, MPEG2VCR, Windows Movie Maker, and NERO Movie Maker, but I have yet to figure out how to slow frames down. Is it possible to do with any of my current programs, or is there a program out there that will make this poissible
Results 1 to 17 of 17
virtualdub avisynth premiere vegas etc
. . . . twixtor, combustion . . . . .
..after effects, fusion,......
......Shake, RAYZ, Satori, Chalice, Mirage, Softimage D|S, Houdini, FloMo, Smoke, Flame ........
Do any of these programs generate extra frames in a way that maintains smooth motion?
yes vegas (w/ super sampling), Shake, RAYZ, Satori, Chalice, Mirage, Softimage D|S, Houdini, FloMo, Smoke, Flame, inferno, after effects, fusion, combustion, time master//
twixtor is a plug in for several of the above apps ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
i forgot time master ... and even procoder ... and some of the avid packages ...
I have Vegas 4. The help for supersampling says "Right-click the video bus track, choose Insert/Remove Envelope from the shortcut menu, and then choose Motion Blur Subsampling from the submenu." Subsampling is not one of the options that comes up.Originally Posted by BJ_M
If I insert a velocity envelope and set it to 50% it plays the video at half speed but only plays half of it. How do I slow it down and play all of it?
I figured out how to extend the length of the video by dragging. Is there a way to set the length to automatically include all of the video?Originally Posted by sync
supersampling is in version 5"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
hold the control key down and drag the endOriginally Posted by sync"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I didn't explain myself clearly. Is there a way to have the length of the video automatically adjust for any changes to the velocity envelope so that all the frames are played?Originally Posted by BJ_M
WOW, there are alot of programs out there. I will go with the one that you guys are talking about, since you are giving a tutorial. LOL
TNX
Here's my pennies worth........... Ulead Videostudio 8 allows you to control the speed of a clip down to 10% if you need. Was fiddling with that last night!
Why is it doing that?
TNX Rivers. I like the Ulead Gif Animator, so I will try that software out, definately.
Stop Motion Animation Frame by Frame Capturing
By Fary4u in forum CapturingReplies: 9Last Post: 5th Jan 2012, 16:49 -
Reprogram a Sony DCR-TRV33E for slow frame rate?
By goodnature in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 5th Apr 2010, 13:43 -
Nero Vision (edit:) Motion Adaptive Frame Rate Conversion
By sagat93 in forum Authoring (DVD)Replies: 12Last Post: 3rd Mar 2010, 11:06 -
Slow Frame Rate
By tobymac in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 10th Mar 2008, 13:12 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
