Hi All,
In this thread, http://www.videohelp.com/forum/viewtopic.php?t=145121 , RadicalEd speaks of when to use Full Processing mode vs Fast Recompress. When I do that, using Fast Recompress and Huffyuv, the 4+ minute file is only 1.7G when I was expecting 8+G. If I select Uncompressed RGB, I do not know if I am changing the type from YUV whatever to RGB, especially since I cannot find any way to determine what type my clip is.
When I use Full Processing Mode - contrary to what RadicalEd says - and select Huffyuv, the resulting file is 2.8G. What am I missing? I am trying to convert it so that I can edit the AVI in Premiere LE, and I know the file size should be around 8G when converted.
Thanks,
Dobermann
4:1 or 5:1 compression (vs uncompressed RGB) is not unheard of for HuffYUV in YUY2 mode.
MPEG decompresses to YUY2 or YV12 (both YUV color formats), both of which are smaller than the uncompressed RGB equivalent (YUY2 is 2/3 the size, and YV12 is 1/2). VirtualDub can send that directly to HuffYUV for compression where it gets compressed losslessly by another 2:1 to 3:1.
If you use full processing mode the YUV data is converted to uncompressed RGB (which loses a little color accuracy) before compression. You only need to use full processing mode if you plan to filter the video in VirtualDub.
Thanks ever so much for the explanatin on MPEG decompressing to YUV. So based upon what you have said, the Fast Recompress using HuffYUV would be best, regardless of it being the smallest in size. I did run it four different ways and here are the file size results:
Full Processing Mode using HuffYUV, 2.977 G
Full Processing Mode using Uncompressed RGB, 8.313 G
Fast Recompress using HuffYUV, 1.7 G
Fast Recompress using Uncompressed RGB, 8.118 G
Right?
Thanks,
Dobermann
How do I get best settings for XviD using VirtualDubMod?
By helloworld123 in forum DVD RippingReplies: 4Last Post: 17th Aug 2010, 19:14 -
Best Settings in VirtualDubMod to get high qualty video
By hzgg2 in forum EditingReplies: 9Last Post: 20th Jan 2009, 07:44 -
Virtualdubmod Interleaving settings
By dvdfreak1971 in forum AudioReplies: 1Last Post: 29th Apr 2008, 09:55 -
MPEG2 to Xvid with Virtualdubmod
By Cazz in forum EditingReplies: 25Last Post: 26th Feb 2008, 13:49 -
How to set audio conversion settings in batch mode for VirtualDubMod?
By montango in forum Video ConversionReplies: 2Last Post: 14th Jan 2008, 03:56
Statistics
Newest guides
Latest tool updates
New media comments
