VideoHelp.com Forum
  1. Member lacywest's Avatar
    I want to get a good LCD Monitor ... okay how about a decent LCD Monitor ... for gaming.
    I currently have a Proview Flat Screen 19" but I am going to be building a AMD 3000 XP 64 Bit System soon .... with a ATI AIW 9800 Pro video card.
    The video has 128 Mb of video ram.
    So ... what are some choices to choose from. I saw a ViewSonic at BestBuy with Half Life 2 ... playing .... looked great.
    A 19" inch would be cool but I believe the price is not cool.
    I noticed my Proview 19" has a distance from bottom left corner to top right corner of 18" inches.
    Can anybody say anything good about the ...
    Balance 19" LCD Monitor, CM2019 at Walmart
    http://www.walmart.com/catalog/produ...3A3951%3A37802
    19" LCD monitor
    DVI digital link
    500:1 contrast ratio
    250cd brightness
    1280 x 1024 resolution
    0.296 pixel pitch
    Description at the bottom says ...
    19" LCD monitor
    DVI digital link, DVI and VGA cable included
    Reaction time (Tr/Tf) 15ms/10ms
    Brightness 250 cd/m
    0.296 pixel pitch
    Digital interface
    2.5W x 2 speakers
    56-75Hz frequency
    AC 100V-AC 240V
    50W power consumption
    Standard 100 mm wall mount
    13 lbs. weight
    50,000 hour lamp life
    I've got the funds to buy now ... especially next Friday ... Feb 19 for sure.
    Thank you ... in advance
    Nothing beats a CRT monitor for gaming and movies too. The only advantage of LCD and Plasma screens is the weight and depth.
    COPIED OVER 600 DVDS SO FAR
  3. Mod Neophyte Super Moderator redwudz's Avatar
    I'm a little skeptical of Balance brand, but I don't know who makes their monitors. I would do a little more research into the monitor. At least Google the model and see if there are any reviews out there. That is a good price and a good spec if it holds up in real life.
    Here's a good article on gaming LCD's, though. http://www.d-silence.com/feature.php?id=249
    And for LCD 19" monitors, this Phillips model has a response time of 12ms:http://www.newegg.com/app/viewproduc...133-147&DEPA=0
    CRTs are generally faster, but not all people have the room for a 19" CRT, besides, you can heat a room with them.
  1. 2ms Vs. 5ms LCD monitors
    By Noahtuck in forum Computer
    Last Post: 16th Aug 2011, 07:16
  2. Are either of these good LCD TN monitors?
    By Stealth3si in forum Media Center PC / MediaCenters
    Last Post: 11th Jan 2011, 08:33
  3. LCD TV vs. LCD Monitor for PC gaming
    By Xenos80 in forum Computer
    Last Post: 12th Feb 2009, 23:01
  4. One LCD is flickering on a dual monitors setup
    By tigerb in forum Newbie / General discussions
    Last Post: 25th Jan 2009, 03:19
  5. Why LCD monitors have still VGA connections?
    By Talayero in forum Computer
    Last Post: 13th Apr 2008, 02:05
