VideoHelp.com Forum
  1. Ive been using WinAVI converter for some time and i think it awesome but i wish there was a authoring program that provide the same speed and quality of encoding avi ( dvix xvid ) to DVD format while alowing a powerfull menu creator and multiple clip combiner. Ive used TMPEG authering software and wasnt impressed by the quality, ivwe also tried Nero Vision but the conversion proccess is just to slow. If anyone here know of any good software the incorporates all the pro of WINAVI conversion and has a decent amout of feature then please list them.
    Thanks,
  2. Hey, i aslo use winAVI to convert my movies, but to author them I use DVD-Lab Pro. It's a very cool program and offers intermidiate authoring capabilities.
    It looks complicated @ 1st but a guide and a few hours fooling around with it will set u on the right path.
    Another program is Pinnacle Studio Plus, I hear it's amazing as well but i haven't tried this one myself.
  3. avoid pinnacle studo - save yourself..looks great, but is riddled w/ bugs - some lucky ones get it to work but many don't .. this should really be a class action law suit - some smart lawyer could do well w/ it...
    dvd-lab (regular or pro) is good (but it does not encode - you will do that outside dvdlab) ..
    "As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
    Best for what?
    What do you hope to accomplish.
  1. Simplest DVD authoring program?
    By paristideu in forum Authoring (DVD)
    Last Post: 28th Dec 2011, 11:08
  2. A good dvd authoring program?
    By t_jay17 in forum Authoring (DVD)
    Last Post: 31st Mar 2010, 21:50
  3. Which dvd authoring program could I use...
    By sagat93 in forum Authoring (DVD)
    Last Post: 14th Oct 2009, 21:43
  4. which dvd-authoring program is better?
    By siluet in forum Authoring (DVD)
    Last Post: 8th Oct 2008, 14:25
  5. The Best DVD Authoring program
    By Random490 in forum Authoring (DVD)
    Last Post: 12th Dec 2007, 04:10
