I have a pretty high end Sony DVD player that I bought 4 years ago. Been running smooth until about a month ago.
One some of my DVD+Rs after about an hour of play the picture gets pixelated, freezes and skips back to an earlier chapter of the movie.
I know the DVDs are fine because they play without error on my other 2 more recently purchased DVD players. Also if I turn the DVD player off for several hours it will play the same disc all the way through without problems.
Is there any kind of regular maintenance I need to perform to keep this from happening?
Are you a smoker?
If so you may need to carefully clean the lens on the laser LED.
Don't smoke but I suppose it could be dust.Originally Posted by jameshgross
Is the lens obvious if I open it up and is there any special cleaning considerations?
Get some 'canned air' and try blowing it into the lens area. Sometimes that all that's needed if it's just dust and not grease or smoke contamination.
To clean the lens in most DVD players means taking it apart. But open up the tray and shine a light in there, may be enough room for a cleaning swab. I use denatured alcohol and a long foam Qtip type swab. Don't get the swab too wet, you don't want to wash the lube off the laser slide.
Sounds more like bad media than dirty drive.
Could also be heat.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
They all play just fine in my other 2 DVD players.Originally Posted by lordsmurf
I just use a lens cleaner on mine. You can buy them at most stores that carry cd's and dvd's. A cd cleaning disk will work on a dvd player just as well. It's just a disk with some fine brushes to clean the lens when it passes over the laser.
It sounds like the player is overheating.Open the case(unplug first) and blast everything with a can of air,then move the player away from other components.
If it still stutters then buy a new one.
Which filters to use to clean this DVD source?
By ak24 in forum RestorationReplies: 5Last Post: 30th Jul 2011, 23:11 -
How do I clean up (trim) beginning and end of DVD?
By perceptionist in forum EditingReplies: 6Last Post: 28th Mar 2010, 00:29 -
Where can i download clean and simple dvd menus?
By yuval83 in forum Authoring (DVD)Replies: 0Last Post: 22nd Feb 2009, 07:17 -
clean DVD drive
By avextraxjp in forum Newbie / General discussionsReplies: 15Last Post: 2nd Jul 2008, 09:48 -
Capture DVD to be edited/clean?
By mlong30 in forum CapturingReplies: 13Last Post: 17th Jun 2007, 22:13
