My mates DVD Player is jumping when playing any movie
Would the cheap Sub Woofer speaker he has next to the DVD Player cause his heads to go out of alignment
is this possible ?
probably not, it would mess up his tv if the sub is big enough but we've never run into that issue.
COPIED OVER 600 DVDS SO FAR
OK cool,
what about the vibration from the subby ?
An Unsheilded sub, or any unsheilded speaker would affect the PT, not the dvd player, except maybe the vibration from the sub making the dvd/cd player skip which i have had happen..... 8)
Originally a member since 2001, LONG LIVE TARAN's!!!
It is possible the vibration from the sub is causing it to skip, especially if it is in/on the entertainment unit. Try disconnecting the sub and see if that makes a difference. If it is the sub, you can try turning down its gain or moving it to another location.
Is it on a carpet or wood floor? If it is a "crappy" sub, I doubt that it could put out enough lows to make a dvd skip, most player have safeguards against skipping.
#1: a dvd player does not have "heads"Originally Posted by Sifaga
#2: see my previous post which suggest's the same thing as OmegaSupreme said.......Originally a member since 2001, LONG LIVE TARAN's!!!
Sound only coming from subwoofer
By jeanpave in forum AudioReplies: 11Last Post: 5th Oct 2010, 00:24 -
Subwoofer and speaker problems
By HartsVideo in forum AudioReplies: 10Last Post: 20th Sep 2008, 12:18 -
Subwoofer Help
By levon in forum AudioReplies: 9Last Post: 3rd Sep 2008, 13:41 -
Ground Loop problem. Subwoofer hum. Will this gound isolater work on HD
By Denvers Dawgs in forum DVB / HDTVReplies: 3Last Post: 16th Jun 2007, 23:43 -
Seting up a subwoofer: what is a corssover? Energy S8.2
By Rudyard in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2007, 00:44
