Dear Evereybody!
A have read through many of the realted topics, but somehow I coldn`t figure out the best and easiest way of converting and editing big dv type2 avi files!
First of all I have captured a 80 min. DV casette with WinDv, so I got a big 16 gig avi file!
A want to edit this movie with a program, that can cut out parts from it, can add overlay effects, music, etc....(I used Ulead Video Studio 8, but if there is a better solution pls. share it) I don`t know, should I adjust these modifications after deinterlacing and converting(compression) or before these steps!
I want to get the best quality, but with the limit of 1-1.5 hour=1 DVD(4.7GB) I would like to use this DVD on computer, so deinterlacing can`t be skipped...
All in all I would be thankful for the correct steps from the beginning to the edited, converted, deinterlaced DVD sized video!
Thanks your replies in advance
Bye
Hi bubu001,
Welcome to the forums.
You can fit more than 1 - 1.5 hours on a DVD. The key is to use compressed audio (like AC3 @ 224kbps), do a 2-Pass VBR encode with a dedicated encoder with an average bitrate that allows you to fit your footage on to one disc.
Use the VideoHelp Bitrate Calculator to figure out the bitrate (use as the average in 2-Pass VBR). A rough guide is anything down to around (approximately) 4,500kbps can be OK for a DV source. It depends on the speed of motion and the complexity of the footage (i.e. scenes with lots of information, such as fire, will need higher bitrates).
De-interlacing, I believe, has no effect on filesize. Footage should be interlaced if it is to be watched on a TV.
These old posts of mine might help:
http://www.videohelp.com/forum/viewt...=725433#725433
http://www.videohelp.com/forum/viewt...107545#1107545
Also, you may consider encoding at half-D1 resolution (352 x 480 / 576 - NTSC / PAL). This will allow for lower bitrates and so a lower filesize for the same footage duration, meaning more footage on a disc. The trade-off is that the picture will be softer, less crisp.
Hope that helps for starters. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
avchd to deinterlaced avi
By cesarin in forum Video ConversionReplies: 17Last Post: 25th Jul 2010, 12:01 -
Converting a 60fps .MTS video to a 30fps raw .AVI?
By Krynj in forum Newbie / General discussionsReplies: 1Last Post: 20th Jun 2010, 15:57 -
Adult video captured in HD mpeg2, edited then rendered to wmv.
By sinnistar in forum Video ConversionReplies: 14Last Post: 12th Aug 2008, 00:06 -
UnViewable type2 AVI
By psxiso in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 12th Sep 2007, 21:35 -
Converting MPG to AVI type2 (batch)
By statman24 in forum Video ConversionReplies: 8Last Post: 19th Jul 2007, 04:30
Statistics
Newest guides
Latest tool updates
New media comments
