I seem to have a small problem. I've burned a couple of dvd's and the menu music in all of them them skips and jumps on my standalone player. However, this does not happen if I play the dvd on my pc using Power DVD. I have been using an mp3 file from my HD for the menu music and have chosen the "custom" - "encode to mped audio" in the menu settings. Do you think changing the option to "encode to ac3 audio" would remedy the problem? I am certain the mp3 is fine as it plays fine on the dvd with Power DVD. I ask this question because in the menu options it says to choose mpeg audio or ac3 audio depending on your player. Could it be that my player does not play mpeg audio correctly? Oh, and by the way, I am using rc2 registered version.
Results 1 to 14 of 14
Certainly try "Custom: Encode to AC3" and let us know if this works better.
AC3 doesn't work for me either. That blows. I was hoping to be able to add music to the menu.
ok. Can you upload the following:
menu jpg
menu mp3 (original)
menu mp2 (48Khz)
dvdlab menu vob & ifo
to ftp://BetaTester:badger@ftp.svcd2dvd...20menuskipping
and i will investigate.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
OK, done. This vob and ifo were from a tester that I did of a very small mpg file so it would be quick to test the menu skipping.
ok. Thanks, got those. I will do some analysis (in the morning) and will probably need you to do a few tests... Is that ok?
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Sure. I'm a newbie so you'll have to make your requests very clear if you know what I mean! LOl!!!
Can you have a look at the two DVDs in ftp://BetaTester:badger@ftp.svcd2dvd...skipping/Tests
Try burning those (RW media) and see if there is a difference.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Unfortunately, both still skip in my dvd player. I don't know if it makes a difference to you what dvd player I have, but it's a Norcent DP311.
I would just like to give a formal thank you to Chrissyboy for solving this problem. A couple of emails back and forth and he's gotten everything straightened out. Cheers to you my friend. Your work is greatly appreciated.
what was the solution then as i get the same problem?
The solution is a different encoding method for the menu. It will be available in RC4. I will email you a intermeadiate version.
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
New music skipping
By Jeikobu in forum Portable VideoReplies: 0Last Post: 24th Jan 2009, 13:13 -
Skipping a menu on a DVD
By Luriden in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2008, 22:03 -
burning music to cd so it will play in car or standalone cd player
By deadman1972 in forum AudioReplies: 4Last Post: 8th Aug 2008, 05:43 -
Menu Problem - Skipping
By vinnyv07 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th May 2007, 19:17
