Hi Major,
I've a problem with a S version of ffmpegX: always I launch the application it tell me install mencoder binary's.
Have you a suggest?
Thank you.
LuKe
Results 1 to 10 of 10
Thread: Binaries
Check the size of your mencoder binary file. If it is not 6636100 bytes, then download again the correct version.
I had the same problem, it kept asking me to install the file each time I started ffmpegX and it was the right version, for some readson the installer was not installing it.
Eventually I unziped the file and copied it manually to /Library/Application Support/ffmpegX and that was the end of the problemRuben Leon
Dept of Computer & Information Science
Strathclyde University
Scotland
I have no idea why this happens. In my case it only happened when I ungraded to 's' and not before. At first I thought it might be related to permissions so I tried installing it as root, but that was not the problem.
If you press cancel to the request for installation, are you still able to use mencoder and mplayer ?Ruben Leon
Scotland
Thank for your help.
I've dloaded new binaries and its run good: I've installed 230105 binaries even if ffmpegX tell me 180105.
I see in the installation binaries panel that there isn't a option to install real binary: it's not supported on S version of ffmpegX?
LuKe
Sorry I don't understand what you mean by "real binary". All three instalation files (mencode etc) are compiled executable code.
There is 'option' menu in the 'S' instaler version but you can bwose and chose whatever file you want to install.
You can compile your own from the sources and optimise it for your hardware and OS. I noticed that the mencode that we are using is fairly old (over 2 years old I think) probably compited for Mac OS X.1 . Major will know about this. Personally I'll stick to the available binary for the time being.
Cheers
I meant to say:
There is no 'option' menu in the 'S' instaler version ... (etc)Ruben Leon
Scotland
updated to version S - no more prompts to re-install the binaries. all is well.
Check http://homepage.mac.com/major4/download.html for instructions about the optional real libraries install. This is only needed if you are interested in opening RealVideo files.
Newer Binaries?
By theorik in forum ffmpegX bugs and suggestionsReplies: 0Last Post: 30th Sep 2008, 02:39 -
ffmpegX additional binaries - where the h*ll should they be?!
By nickelbump in forum ffmpegX general discussionReplies: 10Last Post: 31st Dec 2007, 20:12 -
installing Binaries
By mahanpots in forum ffmpegX general discussionReplies: 1Last Post: 14th Dec 2007, 10:16 -
Error while installing binaries!?? help!
By mavenny in forum ffmpegX general discussionReplies: 7Last Post: 8th Oct 2007, 22:29 -
Latest OS X reallib binaries?
By Scallywag in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jun 2007, 17:26
