VideoHelp.com Forum
    Guys,
    I need your help and guidance to check the firmware version on my Pioneer DV-575A DVD Player. Is there any way?
    Thanks in advance
    Bernard
    To check which firmware version you currently have...
    - Power on the player
    - Go to Home Menu
    - Choose "Initial Settings"
    - Go down to Options (do not enter sub menu)
    - Press Display on Remote
    Hey Presto!
    Thanks Micol,
    It works
    Anybody can help me to see the MP3 ID3 tag in Pioneer DV-575A players.
    Bernard
  5. Hi, MICOL. I own a Pioneer XV-HTD540 (the DVD player included with the HTD-540DV home theatre system). Being that the menu configuration matches that of the 575A, I decided to try the instructions you posted and it worked. I would like to either change regions or unlock it completely. However, I understand you need a Palm Pilot and some advanced files. Can anyone tell me if there is anything whatsoever I can do with the supplied remote even just to change the region every time I load DVDs from different countries? Thank you.
    - Go to Home Menu
    Hey Presto!
  1. Pioneer DV-S838A firmware
    By zhudinglong in forum DVD & Blu-ray Players
    Last Post: 21st Jul 2011, 01:12
  2. Replies: 4
    Last Post: 25th Sep 2010, 15:35
  3. Pioneer DV-220V-K firmware version?
    By batyar55 in forum DVD & Blu-ray Players
    Last Post: 20th Jun 2010, 13:27
  4. Pioneer DV-220V-K firmware
    By totonionio in forum DVD & Blu-ray Players
    Last Post: 8th Feb 2010, 05:30
  5. Warning-problem with WD TV LIVE Players firmware release version 1.01.12
    By MJA in forum Media Center PC / MediaCenters
    Last Post: 10th Dec 2009, 14:24
