I have a home-made DVD I got from a friend but one of the submenus seems to have been made improperly and lacks a button that takes you back to the main menu.
The DVD player also "remembers" the last point you had running in all your DVDs, so whenever I try to play that disk I can't leave the sub-menu to play the movie.
Main Menu, Return, etc all do nothing by either not functioning at all or coming up as a red cross telling me it's an improper command I would guess.
Does anyone have any advice? I've heard reseting it could be a solution but I'm concerned about doing that since it's a speciality device (GameCube DVD Player hybrid), and also because I purchased it as a regionless player and I'm worried a reset may set it fully back to factory defaults.
Thanks so much for your help in advance!![]()
Results 1 to 1 of 1
Thread: Panasonic Q (R31) question...
Question about SD card for Panasonic HMC150
By jeanpave in forum EditingReplies: 11Last Post: 11th Jun 2011, 22:11 -
Quick Question, Re: Panasonic SD10
By Verta in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 8th Apr 2010, 08:06 -
Panasonic Firmware question
By vetski179 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2009, 19:30 -
Panasonic AY-DVM83MQ vs. Panasonic AY-DVM83PQ and AY-DVM80XJ question.
By Cyrax9 in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 26th Feb 2008, 12:37 -
Question on new Panasonic dvd recorders
By heman28 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 20th Feb 2008, 11:37
