Hello all,
I have a DivX video file that I'd like to play using this DVD player. However, when I first put the disc in, the color is very distorted and the DVD is unwatchable. I did a forum search and found an easy fix. Simply hit the "System Menu" button twice and the color returns to normal.
However, whenever I do this, the audio in the file becomes out of sync with the video. When the picture was distorted, the video and audio become out of sync. What can I do to fix this?
Mike
Results 1 to 11 of 11
covert again the avi file in virtualdub (video in divx compression) and audio in MP3 compression 48kHz 128kbit/s if you find an audio skew, otherwise in audio section use direct stream copyOriginally Posted by Mike_A
cosma
I'm sorry, but my post was confusing. What I meant to say was the following:
When the picture was distorted, the video and audio DO NOT become out of sync.
In other words, the video itself is fine. Should I still re-encode?
First try an experiment, as silly as it might sound: Burn the video first on the disc, and something else last (like an MP3 file or a small AVI file, about 1 meg in size). Now see if this helps with any of your problems.
This player is very sensitive to disc quality, and will act weird if it doesn't like the disc. Often doing as I suggest above can help... at least it helps with my particular player. I never burn a single .AVI onto a disc anymore, I always put something else last after the main movie. This has cured many of my problems. I never seen to notice any desynched audio/video anymore.
well, where's the problem?Originally Posted by Mike_A
follow these steps:
If the video is incorrect, audio OK - use virtualdub (video normal recompress, audio direct stream copy)
If video is good, audio bad (time shift)- use virtualdub (video - direct stream copy, audio - save audio to wav then full recompress - compression MP3 - 48kHz, 128kbit/s)
If both are bad - use virtualdub and recompress both (audio - save audio to wav then full, video - normal recompress)
cosma
Well, the video itself isn't the problem. The audio becomes out of sync when I do the "fix" for the DVD player. The picture then looks fine, but the audio is a few seconds slow. Do you see what I mean?
Mike
yes, the problem is bad "audio header" according to virtuadub....Originally Posted by Mike_A
encode audio and video i virtualdub and audio will be OK, and you wont need to fix the video anymore (it wil fix everything)
do not forget to save audio to wav and when encoding audio choose audio source from this wav file
cosma
Thanks cosma.
hey dude i would just try to restream the audio and video in vdubmod and see if that fixes it,,before doing all the recoding,,that will prob fix ur sync issue,,recoding video should always be last resort,,
Hmmm, that does seem more efficient. I'll try that out first. Thanks.
i told you if audio shift was the only problem recode audio, not video- read more carefully (but you will not solve the blurring picture problem - you have to always use "system button"Originally Posted by Mike_A
the option "direct stream copy" means - no encoding just copy the video (audio) as it is.....
if both are bad (audio and video) recode both
How To Fix Audio Sync Problems 102
By gcsnelgar in forum User guidesReplies: 32Last Post: 25th Feb 2011, 20:04 -
Video Audio Sync Problems
By Johnnysh in forum DVD RippingReplies: 11Last Post: 26th Jan 2011, 01:47 -
My fraps audio and video is out of sync. How do I fix it?
By dxdiag in forum CapturingReplies: 3Last Post: 21st Dec 2010, 21:53 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
How To Fix Audio Sync Problems 101
By gcsnelgar in forum User guidesReplies: 2Last Post: 24th Jul 2007, 12:11
