Does anyone know how I can encode MPEG4 with an Osprey Capture Card? And also, most importantly what software I would need for that?
A step by step instruction/tutorial would be helpful! Thanks!
Results 1 to 18 of 18
which Osprey Capture Card? they have like 15 of them
http://www.viewcast.com/products/osprey.html
For questions, please contact us at info@viewcast.com or call toll-free (US only) at 800.540.4119 or (international) +1.972.488.7200."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
osprey 210 analog
I looked through the manual http://www.viewcastonline.com/downlo...2kntmanual.pdf
and it uses vfw (assuming you have installed the drivers) , amcap will not work , but virtualdub should - for capture ..
but what kind of mpeg4 do you mean ? there are many different types and you might have to cap in one format and convert .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
i asked someone and they told me to use the amcap and then re-encode to mpeg4
you might want to check with the link i posted above ."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
ok what i would like to do is play video files on an epson P-2000... there's the link below with its specs...
http://www.epson.com/cgi-bin/Store/c...egory=Products
from what i understand it plays MPEG4? so i would like to convert say (ex.) DVD's or another video file type to MPEG4 and watch them on the epson. is this possible? what would i need to use.. programs.. etc.. thanks.
it plays mjpeg it says for video
Video File Format
* Motion JPG
* Maximum resolution 640 x 480 pixels
* Minimum resolution 160 x 112 pixels"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
sorry i'm new to this. so that what does that mean exactly? i would have to convert my files to mjpeg not mpeg4? would this have sound though?
what do i need for this? what kind of software? any tutorials available?
the mpeg4 is (oddly) for audio only the way it is listed..
the mjpeg it supports is the mjpeg format that the matching camera outputs --
so you need to find that out --
you could use a demo of a mjpeg codec and see if it will work -- many diff. types though"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
yes - mjpeg supports sound (as listed) .
you can use virtualdub for this - but you will need to buy a mjpeg codec (pic video for example) , but i dont knwo if that will work --
can epson send you a sample file or get you more info on what that camera outputs ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
i found the "User Manual" for the camera in the link below... i hope it helps...
http://www.epson.com/cgi-bin/Store/s...odoid=49164278
i believe there is more info under "viewing and playing images, audio, or video"... page 28... but i have no idea what all that means... what do you think? thanks again.
well - the info there conflicts with the info on the other display device ..
says here it does support mpeg4 AND mjpeg for video
if you use mpeg4 though - you are limited to 24fps and 1.5meg/s bit rate
mjpeg is 30fps or 24fps at 3meg/s
i take it that you should be able to use Quicktime Pro (pay version) and render to mpeg4 or mjpeg and it should work ..
also - v-dub with a mjpeg codec ..
squeeze, vegas, procoder2 are also other apps that will work ..
audio you have a lot of choices -- use AAC , mp3 or Alaw (in order)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
so mjpeg would be better than mpeg4?
so what would be the easiest way to go? convert say dvd into mjpeg or mpeg4 using quicktime pro 6.5? using the capture card? or?
i need something really simple.
well if the file already exists - the capture card is useless
and it is not so easy to import dvd into QT pro ..
how much you want spend ? procoder would be perfect for this"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I really don't want to spend too much unless it's really worth it. What is procoder? is that better than quicktime pro for what I'm trying to do?
Thanks.
yes it is -- but it is $500
ouch... a little over my budget.
so is mjpeg or mpeg 4 better/easier to encode?
i guess i will try the quicktime pro if mpeg 4 is better or..
if mjpeg is better i will try v-dub with a mjpeg codec ... where can I find this anyway?
Osprey 440 card capture video in mp4 from live stream
By vrparekh@gmail.com in forum CapturingReplies: 1Last Post: 13th Apr 2012, 05:21 -
Viewcast Osprey 230 PCI Captire Card - Any Good ?
By wet bimbette in forum CapturingReplies: 0Last Post: 28th Nov 2011, 06:07 -
Toshiba Camileo H2O and Osprey 210 capture card?
By Amanda28 in forum CapturingReplies: 1Last Post: 17th Nov 2009, 13:12 -
videocast osprey capture resolution
By jaybird in forum CapturingReplies: 0Last Post: 27th Apr 2009, 22:29 -
How to encode Xvid-MPEG4
By hzgg2 in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 16:19
