VideoHelp.com Forum
    Hi,
    It seems there are a few XVID and DIVX I need to re-encode (colorskin is blue and all tips I found did not solve it- note that the majority of Xvid and Divx I play are ok).
    I would like to know what is the best, esiest, and fastest way to re-encode the bad files?
    Using Dr.Divx seems to take quite some time to re-encode a 20 minutes episode... PLus, I don't really know the best settings to choose from and I'd hate to loose quailty of the original video file.
    So, what do you suggest I use to re-encode? Perhaps you can point me to a step by step procedure already posted on videohelp.com? or your own recipe?
    Thank you.
    DrJOnes666
  2. Member Soopafresh's Avatar
    Many ways to do this, and this is a simple one.
    You'll need:
    DivFix
    Gspot
    VirtualDub
    Run the files through DivFix to ensure they are good.
    Open the files in Gspot and write down the video bit rate.
    Open a file in VirtualDub
    Use DivX as the compression.
    Use the same bit rate as the original, or add 100 if you have room on the disk.
    Set Audio for Direct Stream Copy
    Save AVI
    And see if it works.
  1. How to encode xvid with h.263
    By kenryuakuma in forum Video Conversion
    Last Post: 27th Aug 2011, 20:43
  2. No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
    By koberulz in forum Newbie / General discussions
    Last Post: 24th Jan 2010, 04:48
  3. Video Conversion Fu - Why's My Encode So Bad?
    By Keith Justice in forum Newbie / General discussions
    Last Post: 1st Jan 2009, 20:08
  4. Replies: 5
    Last Post: 21st Nov 2008, 16:03
  5. how to encode MPEG4 to play on a phillips DVP-642 player
    By thejunkman12 in forum Newbie / General discussions
    Last Post: 16th Jan 2008, 08:32
