I know there are diff. ways to create a DVD
but I did not see any document which says all in one..
I know I use DVDDecrypter to download to my hard Drive
then DVDShrink to Shrink it on hard drive as an ISO file
then I use DVDDecrypter to burn DVD ...
I also have NERO but I dont use it......
ANyone want to tell any other or better way to do it???
TIA
Results 1 to 14 of 14
Try searching in the guides section on the left (in the Green HOW TO section)
It works well....
I found this one qithout any difficulty
http://www.videohelp.com/guides.php?guideid=676#676
!!A clear conscience is usually the sign of a bad memory.
Just curious why you use Decrypter to burn. I use DVD shrink to shrink down and edit out the credits in the beginning and especially the end of a movie which can be as long as 8 minutes worth of total crap. Then Shrink automatically prompts me to put in a DVD to burn. The only thing is that I think that Shrink burns slower then Nero and the 8 speed of my burner that it should be burning at.
The other thing I think, though others may correct me, is that that I don't think you need DVD decrypter at all for movies before Macrovision which I think was started in about 1998. I have successfully used DVD shrink on ripping many older DVD movies without DVD decrypter.
Made 100's of dvds using this method with out a single coaster.....(Does depend on the media you choose....TY/Verbatim/made in japan.....)
How to back up a STORE BOUGHT dvd...
If backing up to a single layered dvdr
1. DVDDecrypter (Save on HHD)
2. DVD2one (Shrink to fit)
3. Copytodvd (Burn)
If backing up to a dual layered DL dvd
1.DVDDecrypter (Save on HHD)
2.DVDDecrypter (Burn)What We Do In Life, Echoes In Eternity....
newhere,
1 - If you're happy with the results that you are getting then you are doing absolutely fine. Nothing wrong with that setup.
2 - I happen to use DVDDecrypter to copy, Instant Copy 7 to reencode and DVDDecrypter to burn.
3 - See #1Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
Removed.
Refer to previous post for revisions......
I think he was referring to your source disck. If the source disc is single layer you don't neeed anything but decrypter, if it's a dual layer disk you shrink it down to fit on a single layer (most people don't use dual layer discs yet)
Oh, I was starting off with a movie Industry dvd (store bought) to be backed up. To either a single layered dvdr or a dual layered (DL) dvd. I'll edit my previous post
I asked this question because I am happy with the DVDs I can burn
but will every 2 DVDs I burn I get one I/O Error and DVD is waste...
So I was thinking if there is a better way to do it, or some precautions to prevent the errors.
TIA
1. Use Shrink to re-author, encode and shrink to a single ISO file on your HDD. The drive you are sending the image 'to' has to be formatted NTFS. If the drive is formatted Fat32 make the ISO images in 1g blocks.
2. Use Decrypter to burn the ISO image.
A simple, quick, 2 stage exercise that will make all of your problems go-away. More importantly, both applications are free.
Well I dont re-author it... do you think that is the problem...Originally Posted by blinky88
I just use decrypter to download to HD and then DVDShrink to shrink and create one ISO file...
and the decrypter to burn.....
I get all the error while burning...
If you do not re-author, you will finish up having a lot of compression in Shrink which can take a long time to analyse and encode. I re-author each backup as all I want is the picture. If I want to see the trailors etc. I can always use the original DVD. Re-authoring the main picture only shortens the process.
Forgot to mention, I uncheck both burn with DVD Decrypter and Nero. I manually start Decrypter and choose the image to be burned.
If you elect to use the method as described earlier, I feel certain you will not experience any errors unless you are using bad media.
Overwhelmed - DVD Creation Process...?
By SixOclock in forum Authoring (DVD)Replies: 8Last Post: 17th Aug 2009, 11:46 -
Does SVCD2DVD process and burn HD quality DVD from HD .ts file?
By jeemak in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Nov 2008, 22:03 -
Best process for DVD to MKV?
By zsad in forum DVD RippingReplies: 10Last Post: 12th Nov 2008, 10:00 -
New DVD writer... Burn process failed at 2x (2,770 KB/s)
By planetx in forum DVD & Blu-ray WritersReplies: 8Last Post: 8th Feb 2008, 15:40 -
AVI to DVD process
By Vipero00 in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2007, 01:44
