Hello,
I am trying to capture with the divx codec and the lame mp3 codec using several different capturing progs. I installed the lame codec by right clicking the lame inf and clicking install. It then shows up under audio codecs along with the fraunhofer version. I must disable the fraunhofer to get the lame codec to show up as an option in the capturing software. One I've tried is mainconcept. My goal is to get 44.1khz mp3 with the captured divx. the fraunhofer only list up to 22khz sampling. I am trying to stream the caputred video to my D-link dsm320 media player. It plays converted mpegs to divx perfectly. My steps are open mainconcept - go to setup, select 480x480, divx 5.11 video and lame mp3 codec at 44.1khz. After capturing I play the video and there's no audio. Gspot shows the audio as mpeg layer 3 - 2 codecs compatible installed 164kbs. Video plays fine, just no audio. If I capture with no audio compression (PCM) audio plays fine. I am running prescot 3.0Ghz with 1mb cache so that shouldn't be a problem. I am running a Hauppage wintv with no hardware encoding and winxp pro. I've tried mainconcept, gotallmedia, dr divx all with no luck. If I convert a file with dr divx it plays fine. Just won't capture the mp3 audio. Can anyone tell me how to set up to capture mp3 at 44.1khz?
Thanks,
vifa
Results 1 to 1 of 1
Lame MP3 Encoder on Vista x64
By edt in forum Newbie / General discussionsReplies: 19Last Post: 26th Mar 2012, 17:56 -
MP3 (LAME) in Avidemux
By moiz in forum AudioReplies: 2Last Post: 18th Feb 2012, 10:18 -
Lame MP3 (or any MP3) in Sony Vegas 7
By boom731209 in forum AudioReplies: 7Last Post: 28th Oct 2010, 16:13 -
Cannot install lame mp3 on vista x64
By jarko in forum AudioReplies: 14Last Post: 28th Apr 2010, 03:12 -
MP3/LAME and H264/X264
By Xavier in forum Newbie / General discussionsReplies: 3Last Post: 15th Apr 2008, 22:53
