I recently recorded a music concert on CMT (Country Music Television) on my DVD recorder. I extracted the VRO file using ISOBuster, and was able to load it in TMPGEnc DVD Author to make a DVD.
Then I recorded a show (Pompeii) on the Discovery Channel, did the same thing, but TMPGEnc DVD Author complains "544 x 480 resolution can not be used for standard DVD"
TMPGEnc DVD Author says the first file is 720 x 480. Why is the second one 544 x 480? Same DVD recorder, same digital cable box.
Thanks for any answers! I'm sure I'm missing something simple....
Thread: Resolution on VRO files?
You have used different recording modes. Longer time recording mode uses lower resolution.Originally Posted by stevedore
Make sure you initialise your disc/record in DVD-VIDEO mode rather than DVD-VR to ensure a compliant resolution whatever your recording length.
Thanks for the replies. I hadn't thought about resolution with the different recording modes, and assumed only the bitrate varied. I need to learn some more about this stuff.
I'll do some tests in the different modes & see what I get.
Thanks again!
You don't need to use isobuster to extract the vro, just use the add dvd video on TDA and point it to the folder where the vro file is
It will then show you all the titles you have and then it will extract the mpgs to a folder you've specified
Then do your editing etc....
If you're using ISOBUSTER because you can't see the contents of a DVD-VR disk in Windows Explorer (or TDA), and you've got a Pioneer drive in your PC, check out http://www.softarch.com/pioneer/readdvd.html (it's free for Pioneer drive owners - solved the problems I was having reading DVD-VR disks recorded on my 420H)
VRO Files
By bz186 in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 3rd May 2010, 10:11 -
MPEG Streamclip VRO Files
By bz186 in forum EditingReplies: 0Last Post: 10th Sep 2009, 15:06 -
Extracting .VRO files???
By jbrdbr111x in forum Video ConversionReplies: 12Last Post: 24th Jun 2009, 20:34 -
Editing/converting VRO files
By mariqueri in forum Video ConversionReplies: 28Last Post: 20th May 2009, 12:25 -
VRO files
By tvlreject in forum Newbie / General discussionsReplies: 14Last Post: 8th May 2007, 13:31
