VideoHelp.com Forum
Thread: Encodings
  1. Glad to see the forums are back up. How come discussion boards always go down a couple hours before you realize you have to ask a question?? Anyway, here's my little situation. Up until recently I'd be using DVD Shrink to reduce my DVD9's to DVD5's for burning. A friend told me about DVD-RB and CCE, so I did a bit of reading. Apparently it's unanimous that CCE is the best encoder for backing up DVD media, so I decided to try it out. I used the DVD-RB tutorials, especially the ones at Afterdawn to give it a shot. All seems to have worked, but now I want to actually evaluate the results, and as silly as it sounds I can't seem to think of an easy way to do it. Basically I just want to be able to do a visual comparison of a regular DVD-Shrink backup with my DVD-RB CCE backup (and maybe between a couple CCE backups with different settings/filters). The problem seems to be that non of my normal DVD playing apps support multiple instances, so I can only have one version showing at a time. What's the best way to do some simple visual comparisons?
    Introduction > Musicmatch Screen shot > Musicmatch Jukebox Plus
  2. Get PowerDVD and use it to take snapshots of certain frames. Use those for comparison. Either that, or use VirtualDubMod to take DVD video and take it back to an uncompressed AVI. The conversion should be lossless, but you can probably open each one up in a separate Windows Media Player or something to do a side-by-side.
  1. x264 encodings playing on TivoHD
    By txporter in forum Newbie / General discussions
    Last Post: 13th Nov 2009, 10:42
  2. encodings troubles
    By Benjy in forum Blu-ray Ripping
    Last Post: 23rd Oct 2009, 00:22
  3. Replies: 5
    Last Post: 24th Nov 2008, 05:31
  4. Better quality DivX encodings???
    By smt_88 in forum Newbie / General discussions
    Last Post: 10th Oct 2007, 00:13
