VideoHelp.com Forum
  1. Yes I know 15gb of Mpeg2 video will not fit on a 4.7 or 8.5 disk, but I would like to create the files needed for DVD anyway (vobs , etc).
    Tmpeg Author reminds that the content is too big for a disk, but I would like it to go ahead and write the content to hard drive (video_ts,etc). It gets half way through and stops , saying its too big for a DVD disk (even though I said OK , when it warned me before I started).
    The reason for doing this, is that I want to use DVD shrink to analyze the Tmpenc DVD author output and see what it can fit onto 1 or 2 disks from this one mpeg.
    Do I have to use the Tmpeng converter first ? Is there a work around for DVD Author?
    thanks, zep
  2. Member bugster's Avatar
    The Max size for a DVD is ~8.5 Gigs as this is what you can fit onto a DV DVD. If your source files are bigger than this you will need to re-encode with a lower bitrate first.
    There are 10 kinds of people in this world. Those that understand binary...
  1. DVD player won't recognise hard drive
    By Danny01boy in forum Newbie / General discussions
    Last Post: 13th Aug 2011, 21:43
  2. Tmpgenc dvd author 3 will not author my m2v files????
    By biged670 in forum Authoring (DVD)
    Last Post: 28th Sep 2009, 11:10
  3. TMpegEnc DVD Author won't fill a 4.7 GB DVD
    By jagojon3 in forum Authoring (DVD)
    Last Post: 29th Dec 2008, 18:32
  4. TMPG DVD Author 3 won't open FVFW avi
    By jasoncolz in forum Authoring (DVD)
    Last Post: 7th Dec 2007, 15:21
  5. Simple Menu but movie won't run - TMPGEnc DVD Author 3
    By gayclarke in forum Authoring (DVD)
    Last Post: 14th Sep 2007, 09:00
