Is anyone else experiencing audio stuttering with certain xvid files on the 642? I've been noticing it on recently downloaded TV eps. If there is a workaround or something, I'd greatly appreciate it!
Thread: stuttering on philips 642
try using a prog called MPEGmodifier (search for it in tools) and you need to load your file into it and click unpacked then save the file.
This seems to be a common problem with avi's downloaded from the net. there are other issues that could cause it but give this a go.
funny thing is my DK 339 will play some packed files ok
hope this helps (ive only just found out myself but it works for me)
Dave.
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 12:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
Philips DVD 642/37 Mostly a Blue Picture
By Shieh in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2008, 11:32 -
Philips DVP5980 stuttering
By p2tu in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Jul 2007, 12:36 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 14:36
Statistics
Newest guides
Latest tool updates
New media comments
