VideoHelp.com Forum
  1. I have an old samsung dvd player which does not play CD-R's. I wanted to know if there is a way to fix that. I have a VCD which is recorded on a CD-R I am trying to play it. The DVD player does say that it plays VCD's.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You may be out of luck. Older players may play commercial CD VCDs and not burned ones. You might post the model of your player and someone here may have some info on compatibility.
  3. The model # is Samsung DVD 611. Let me know if there is a firware update available.
    THanks
  4. Member hech54's Avatar
    Some older DVD players won't even play music CD-R's. Even fewer older ones can play SVCD's correctly. Sorry man....shit happens.
  5. You're probably stuck on this one. Some older DVD players will play VCDs on CD-R but _not_ music audio CDs on CD-R. My Daewoo 5800, for instance, players VCDs and SVCDs and SVCDs and XSVCDs authored and burned on CD-R...but it will NOT play an audio CD-R. Well...that's what I use my older audio CD player for. Audio CD players typically do a much better job of playing audio CDs, anyway.
  1. No sound when playing playing burned DVD on stand alone player
    By ibzomie in forum Newbie / General discussions
    Last Post: 23rd Aug 2010, 13:11
  2. Samsung BP3600 problem playing Nero authored DVD's
    By stonejg in forum DVD & Blu-ray Players
    Last Post: 10th Jan 2010, 12:56
  3. Replies: 0
    Last Post: 21st Nov 2009, 17:36
  4. my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
    By LEONESVIZZERO in forum DVD & Blu-ray Players
    Last Post: 4th Apr 2008, 09:15
  5. Samsung DVD-1080P7 - Not Playing Widescreen
    By kokaine in forum DVD & Blu-ray Players
    Last Post: 14th Nov 2007, 10:13
