i have several files that play fine unless i ff or use the time skip feature,,then they become way outta sync and do not correct,,ive tried evertything on the remote to fix it,,,i've remuxed one of them with avi-mux but still has same prob,,,will do fine on the pc though,,anyone have any muxing settings that will fix this,,should i use open dml maybe??
Thread: 642 muxing settings
Try AviMuxGui . Make sure the audio file is CBR. Don't encode the audio at too high a bit rate. For testing, try 128kbs.
thats the prog i'm using,,i've tried cbr and ac3 with the file and it still gets outta sync after ff,,,i muxed the cbr with vdub and it worked fine,,but vdub dont seem to support vbr or ac3 as muxing streams,,so i'm trying to find the appropriate setting for avi-mux gui
Download and install the latest GSpot (1.52beta). Then open your avi with Gspot. Look to see if your files have GMC and/or QPEL - You don't want these.
Your problem is not QPEL or it wouldn't play at all. It might have issues with GMC though, and this could be your problem.
Also look at PAR (pixel aspect ratio). This should be 1.00, meaning "square pixels". This could cause issues too if they aren't square (other than 1.00), like the DVP642 might not recognise the file.
i use mpeg4modifier,,,its in the mux
Right, Mpeg4modifier will correct the square pixel issue. Did you use Gspot to see if your files had GMC?
I think GMC is okay for Divx but not for Xvid.
Also if you double click on the system menu to get a semi-transparent background on subtitles, this may have an adverse effect on Divx files while it does the opposite for Xvid files (helps them play better).
no gmc or qpel,,,its in the mux,,,what settings do you use in avimux for the 642??if i have a file with cbr that i mux with vdub and it works fine,,then i mux the original with avi-mux and it dont play right,,that means it comes down to the way avi-mux is muxing it
I am not familiar with Avimux so someone else try to help out on that please.
Muxing with mkvmerge
By sharu006 in forum Video ConversionReplies: 6Last Post: 20th Sep 2011, 04:52 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
Muxing to .mpg
By gameroftheuk in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2008, 12:38 -
Muxing Quality
By BassJunkie in forum MacReplies: 2Last Post: 30th Jul 2008, 08:47
