Hi I have 3 bin files (we might know which ones I have TD) that I cannot burn because I lack the .cue file. I have tried VCD gear and get errors. I have also tried to load the bin directly with CDr win and get an invalid track listing error. So now I'm stuck I've burnt several discs and no luck with this one. I even tried writing my own .cue file but it won't play when I burn it. So if anyone knows how to solve my SVCD TD problem or can post a cue file It would be appreciated.
Try opening the .bin file with isobuster (just do a search on yahoo for it!) and extract the .dat file out of the MPEGAV (or something like that) folder. Good luck!
Nothing is impossible for Dilemma says so!!!!
Try VcdGear to convert bin/cue files to mpeg
http://www.vcdgear.com
One more suggestion: Try to use vcdxrip (vcdimager). If you have one of the GUI's (TSCV, VCDeasy), you may find vcdxrip at the tool tab.
tried vcd gear got errors. Will try isobuster we shall see. I have doubts as I need a .cue file to burn it properly.
This is what u do-
Download WinISO you can get it off of cnet. If you want the crack for it, email me, but anyways-
This will extract ANY cd images files to whatver folder u specify.
Trust me, i use this all the time.
Oh and VCDGEAR- when opening it up, uncheck fix mpeg errors. That should fix everything.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
