Hi all,
I have a laptop equipped with this DVD-Rom which i bought in Hong Kong. For some reason I can only play Chinese DVDs but not dvds of any other countries. I tried using ANYDVD but still it doesn't work. There is no error message that pops up. I have tried using powerdvd and also windvd. no error message. the disc just keeps on spinning but nothing happend. Please help me.
Thread: Toshiba SD-C2502
Maybe your drive has problems reading dual/double layer DVDs (DVD9).
Thank you for your reply.
If that was the case (that my drive has trouble reading DVD-9 Discs), is ther any way to change that?
Maybe you can adjust the laser power setting but I don't know how. Apparently you can do it by just turning on a screw. I have an SD-C2102 that has problems with DVD9s and tried turning a couple of the screws on the laser head without luck.
Ended up picking another Toshiba drive on EBay and using the caddy from the old one. Just have to be careful with the firmware (master/slave settings) on the replacement.
Toshiba dkvr60ku
By bukijami in forum DVD & Blu-ray RecordersReplies: 1Last Post: 10th Nov 2010, 16:28 -
Toshiba RD-XV48DTKB
By maggiechow in forum DVD & Blu-ray RecordersReplies: 6Last Post: 24th Oct 2010, 12:29 -
Toshiba RD-XV48DTKB
By GT40 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Aug 2010, 07:36 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 5th Nov 2009, 08:59 -
Why is the Toshiba HD-A2 Better Than the HD-A3 ?
By ofield1 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 15:57
Statistics
Newest guides
Latest tool updates
New media comments
