I just installed a usb2.0 card my question is can I use the same usb cables that I have from old usb1.1 and have them work with the 2.0 speeds. Or do I need to buy usb 2.0 cables?
Results 1 to 9 of 9
What We Do In Life, Echoes In Eternity....
same
Don't quote me on this, but I think you need 2.0 cables if you're wanting to go over 1.1 speeds. If 1.1 speeds are fine (12Mbps per channel), then you'll be fine.
Nothing can stop me now, 'cause I don't care anymore.
haha...hmmmm? Anyone else like to chime in?
I'm not aware of any difference except the label on the package and the price difference. Of course I mean a USB cable that costs more than a $1.99US.
(But a lot less than $20 in a 36inch cable.)
You don't need special "2.0" cables
I believe that there is no difference other than the price...
thanks all....
Are RCA/composite video cables compatible with audio cables?
By sldvd in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2011, 00:17 -
Extension cables vs Replacement cables
By Novice20 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2011, 20:03 -
Are "thin" coaxial cables just as good as the regular ones?
By True Colors in forum Newbie / General discussionsReplies: 8Last Post: 7th Oct 2010, 20:11 -
Hauppauge 1212 with 4 USB Active Extension Repeater cables
By mail2tom in forum CapturingReplies: 1Last Post: 22nd Mar 2010, 19:52 -
dv cables
By rizvi in forum DVD & Blu-ray RecordersReplies: 2Last Post: 24th Mar 2009, 02:44
